SunilKhanna
    Introduction
    IPv6 host residing in different VLANS communicate via L3 device to route between the VLANS. The solution known as Intervlan Routing or Router on stick, a very well known solution of IPv4. This document is focussed on configuring IPv6 intervlan routing.
    Prerequisite
    • IPv6 Addressing Scheme
    • Intervlan Routing
    • Understaning of Trunk ports
    Background
    Router R1 is connected to a layer2 switch via interface Gig0/0. The Switch interface Fa0/0 is configured as a trunk port to carry data of VLANs 10 and 20. The router interface has two sub-interface Gig0/0.10 and Gig0/0.20 interacting in vlan 10 and 20 respectively. Further there are two hosts, Client1 and Client20 in different sub-net. By default, host of different VLAN do not interact, they need a Layer 3 device to route inbetween. As host, we are using two routers configured with a static routing.
    Topology Diagram
    Configuration
    Interface Configuration
    Complete Configuration
    R1L2-SwitchClient10Client20
    hostname R1
    ip cef
    ipv6 unicast-routing
    interface GigabitEthernet0/0
    no ip address
    duplex auto
    speed auto
    media-type rj45
    ipv6 enable
    interface GigabitEthernet0/0.10
    encapsulation dot1Q 10
    ipv6 address 2012:10:10:10::1/64
    ipv6 enable
    interface GigabitEthernet0/0.20
    encapsulation dot1Q 20
    ipv6 address 2012:20:20:20::1/64
    ipv6 enable
    end
    hostname L2-Switch
    interface FastEthernet0/1
    switchport trunk allowed vlan 10,20
    switchport mode trunk
    interface FastEthernet0/2
    switchport access vlan 10
    switchport mode access
    interface FastEthernet0/3
    switchport access vlan 20
    end
    Client10
    no ip address
    duplex auto
    speed auto
    media-type rj45
    ipv6 address 2012:10:10:10::2/64
    ipv6 enable
    ipv6 route ::/0 2012:10:10:10::1
    end
    hostname Client20
    interface FastEthernet0/0
    no ip address
    duplex auto
    speed auto
    ipv6 address 2012:20:20:20::2/64
    ipv6 enable
    ipv6 route ::/0 2012:20:20:20::1
    end
    Verification Commands
    Note: Client20 from Vlan 20 is able to ping Client10 of VLAN 10.
    References
    Cisco Support: IPv6
    IPv6 Frequently Asked Questions
    rarthurn1
    Community Member
    I Can't access the document! Please provide the link to download the document. Thanks
