Introduction
Stateful NAT64 is a Network Address Translation mechanism for translating IPv6 addresses to IPv4 addresses,  and IPv4 addresses to IPv6 addresses. Like NAT44, it is called stateful  because it creates or modifies bindings or session state while  performing translation. It supports both IPv6-initiated and  IPv4-initiated communications using static or manual mappings. In this document, stateful NAT64 uses static IPv6 to IPv4 mapping for address translations.
Requirements
  • Understanding of IPv6 Addressing Scheme
  • Understanding NAT64
Background
In this configuration example, routers R1,R2 and R3 are connected via fast Ethernet interface.Loopback addresses are configured to generate networks.
The router R1 is IPv6only router which runs RIPv6 with the ASR (Router R2).Similarly the router R3 is IPv4 only router that uses OSPF to communicate with the ASR. The network address translations happen in ASR router using static IPv6 to IPv6 mappings.
Note: All configurations are tested in a lab environment on Cisco 2800 Routers operating on Cisco IOS 15.2 and ASR operating on Cisco IOS-XE 15.1(3)S4version.
Topology Diagram
Summary Steps
NAT64 Interface Configuration
  1. ipv6 address <Specify an IPv6 address>
  2. nat64 enable
  3. exit
NAT64 Mapping Configuration
  1. enable
  2. configure terminal
  3. nat64 prefix stateful <prefix>
Note: The above command enables the router to translate the source IP address to IPv6 by using the  Stateful NAT64 prefix
   4. nat64 v6v4 <static> <ipv6-address ipv4-address>
   5. exit
Configuration
Router R1
IPv6 Only Router
Router R2
ASR Router
Router R3
IPv4 Only Router
IPv6 Only_Router R1#show run
Building configuration...
version 15.2
hostname IPv6 Only_Router R1
ip cef
ipv6 unicast-routing
ipv6 cef
interface Loopback0
no ip address
ipv6 address AB00::1/128
ipv6 rip RIP enable
interface Loopback1
no ip address
ipv6 address AB01::1/128
ipv6 rip RIP enable
interface FastEthernet0/0
duplex auto
speed auto
ipv6 address 2001::A00:A/128
ipv6 rip RIP enable
ipv6 router rip RIP
end
ASR Router R2#show run
version 15.1
hostname ASR Router R2
interface Loopback0
no ip address
ipv6 address BB10::1/128
interface Loopback1
ip address 2.2.2.2 255.255.255.255
interface FastEthernet0/2/6
ip address 10.0.0.2 255.255.255.0
negotiation auto
nat64 enable
interface FastEthernet0/2/7
no ip address
negotiation auto
ipv6 address 2001::A00:B/128
ipv6 rip RIP enable
ipv6 rip RIP default-information only
nat64 enable
router ospf 1
network 2.2.2.2 0.0.0.0 area 1
network 10.0.0.0 0.0.0.255 area 0
ipv6 router rip RIP
nat64 prefix stateful 3001::/96
nat64 v6v4 static 2001::A00:A 10.0.0.10
end
IPv4 Only_router R3#show run
version 15.2
hostname IPv4 Only_router R3
ip cef
ipv6 cef
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Loopback1
ip address 1.1.1.2 255.255.255.255
ip address 10.0.0.1 255.255.255.0
  duplex auto
speed auto
router ospf 1
network 1.1.1.1 0.0.0.0 area 1
network 1.1.1.2 0.0.0.0 area 0
end
Verify Commands
Verifying Connectivity Using Ping Command
To verify whether the router R3 (IPv4 only network) is able to reach the router R1(IPv6 only network), use the ping command and verify the translations that happen by debug ipv6 icmp.
In router R3
Try ping router R1(IPv6 only network)which is represented by the IPv4 address 10.0.0.10. Enable debug ip icmp on router R3 and in router R1(IPv6 only network) enable debug ipv6 icmp
R3#debug ip icmp
ICMP packet debugging is on
R1#debug ipv6 icmp
ICMP Packet debugging is on
R3#ping 10.0.0.10
Sending 5, 100-byte ICMP Echos to 10.0.0.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
R3#
*Sep  8 09:56:22.451: ICMP: echo reply rcvd, src 10.0.0.10, dst 10.0.0.1, topology BASE, dscp 0 topoid 0
*Sep  8 09:56:22.455: ICMP: echo reply rcvd, src 10.0.0.10, dst 10.0.0.1, topology BASE, dscp 0 topoid 0
*Sep  8 09:56:22.459: ICMP: echo reply rcvd, src 10.0.0.10, dst 10.0.0.1, topology BASE, dscp 0 topoid 0
R1#
*Sep  8 10:48:51.499: ICMPv6: Received echo request, src=3001::A00:1, Dst=2001::A00:A
*Sep  8 10:48:51.499: ICMPv6: Sent echo reply, src=2001::A00:A, Dst=3001::A00:1
*Sep  8 10:48:51.503: ICMPv6: Received echo request, src=3001::A00:1, Dst=2001::A00:A
*Sep  8 10:48:51.503: ICMPv6: Sent echo reply, src=2001::A00:A, Dst=3001::A00:1
*Sep  8 10:48:51.507: ICMPv6: Received echo request, src=3001::A00:1, Dst=2001::A00:A
*Sep  8 10:48:51.507: ICMPv6: Sent echo reply, src=2001::A00:A, Dst=3001::A00:1
*Sep  8 10:48:51.511: ICMPv6: Received echo request, src=3001::A00:1, Dst=2001::A00:A
*Sep  8 10:48:51.511: ICMPv6: Sent echo reply, src=2001::A00:A, Dst=3001::A00:1
*Sep  8 10:48:51.515: ICMPv6: Sent echo reply, src=2001::A00:A, Dst=3001::A00:1
From the above debug output, you can see that the router R3(IPv4 only Router) is able to reach the router R1(IPv6 only router) using the static IPv4 address that we have assigned i.e.using 10.0.0.10
Similarly the router R1(IPv6 only router) debug output shows that the ICMP request is received from 3001::A00:1 which is nothing but the IPv4 address 10.0.0.1 when converted to hexadecimal becomes A00:1 and is added to the prefix 3001::/.In other words the IPv4 address 10.0.0.1 is translated to 3001::A00:1 when reaching the IPv6 enabled network.
The following show commands can be used to see NAT64 translations that happen in ASR router
Show nat64 mappings static
To display the information about the Network Address Translation 64 (NAT64) static mappings, use this command.
ASR Router R2#show nat64 mappings static
Static mappings configured: 1
Direction Protocol Address (Port, if any)
   Non-key Address (Port, if any)
v6v4      ---      2001::A00:A
   10.0.0.10
Show nat64 adjacency ipv6
This command displays the information about the Network Address Translation 64 (NAT64) managed adjacencies.
ASR Router R2#show nat64 adjacency ipv6
Adjacency Counts
   Stateless Prefix Adjacencies: 0
   Stateless Prefix Adjacency Ref Count: 0
   v4v6 Stateless Prefix Adjacencies: 0
   v4v6 Stateless Prefix Adjacency Ref Count: 0
   v6v4 Stateless Prefix Adjacencies: 0
   v6v4 Stateless Prefix Adjacency Ref Count: 0
   Stateful Prefix Adjacencies: 1
   Stateful Prefix Adjacency Ref Count: 1
   IPv6 Well-Known Prefix Adjacencies: 1
   IPv6 Well-Known Prefix Adjacency Ref Count: 1
   IPv6 Static Mapping Adjacencies: 0
   IPv6 Static Mapping Adjacency Ref Count: 0
   IPv4 Route Adjacencies: 0
Adjacencies
   Stateful Prefix: ::100.0.0.1
   IPv6 Well-Known Prefix: ::100.0.0.2
   IPv6 Stateful Mask: ::100.0.0.0
Show nat64 prefix stateful
Using this command, you can check the information about Network Address Translation 64 (NAT64) stateful prefixes. Global prefixes, nat64 configured intrerfaces and prefix static-routes will be displayed.
ASR Router R2#show nat64 prefix stateful global (Displays the global prefixes)
Global Stateful Prefix: is valid, 3001::/96
IFs Using Global Prefix
   Fa0/2/6
   Fa0/2/7
ASR Router R2#show nat64 prefix stateful static-routes (Displays the static-routes)
Stateful Prefixes
NAT64 Prefix
   Static Route Ref-Count
3001::/96
ASR Router R2#show nat64 prefix stateful interfaces (Displays the nat64 enabled interfaces)
Stateful Prefixes
Interface
   NAT64 Enabled Global Prefix
FastEthernet0/2/6
   TRUE          TRUE   3001::/96
FastEthernet0/2/7
   TRUE          TRUE   3001::/96
Show nat64 statistics
To display Network Address Translation 64 (NAT64) packet count statistics use this command
ASR Router R2#show nat64 statistics
NAT64 Statistics
Total active translations: 1 (1 static, 0 dynamic; 0 extended)
Sessions found: 142
Sessions created: 16
Expired translations: 16
Global Stats:
   Packets translated (IPv4 -> IPv6)
      Stateless: 0
      Stateful: 79
   Packets translated (IPv6 -> IPv4)
      Stateless: 0
      Stateful: 79
Interface Statistics
   FastEthernet0/2/6 (IPv4 configured, IPv6 not configured):
         Stateless: 0
         Stateful: 79
         Stateless: 0
         Stateful: 0
      Packets dropped: 0
   FastEthernet0/2/7 (IPv4 not configured, IPv6 configured):
         Stateless: 0
         Stateful: 0
         Stateless: 0
         Stateful: 79
      Packets dropped: 0
Dynamic Mapping Statistics
   v6v4
References
Routing Information Protocol
Deepak Ambotkar
Level 3
Level 3
Good one thanks..
Parmanand Patil
Frequent Visitor
Frequent Visitor
I have below router CISCO2921
I want to create a test IPv6 lab.
IPv4 IPs> talking to IPv6 IPs & vice versa.
I copied the config from cisco sites bit didnt help me.
can you please suggest what am I missing here.
As soon as I apply command"nat64 v6v4 list nat64-acl pool pool1 overload" i am loosing connectivity from my IPv4 network towards IPv4 Gw> which is 209.165.201.24.
Device#   PID                   SN
*1        CISCO2921/K9
Router#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M2, RELEASE SOFTWARE (fc2)
Router#show run
interface GigabitEthernet0/1
 description interface facing ipv6
 no ip address
 duplex auto
 speed auto
 nat64 enable
 ipv6 address ipv6 2001:DB8:1::1/96
 ipv6 enable
interface GigabitEthernet0/2
 description interface facing ipv4
 ip address 209.165.201.24 255.255.255.0
 duplex auto
 speed auto
 nat64 enable
ip forward-protocol nd
ip nat translation max-entries list nat64-acl 254
nat64 prefix stateful 2001:DB8:1::1/96
nat64 v4 pool pool1 209.165.201.1 209.165.201.254
nat64 v4v6 static 209.165.201.10 2001:DB8:1::1
ipv6 access-list nat64-acl
sequence 30 permit ipv6 2001:DB8:2::/96 any
savijaysalem
Community Member
explained clean & clear
safwanahmed
Community Member
this example works only for v4 --> v6
an example for v6-->v4 would be great.
thanks
iashaan55
Community Member
Hello Parmanand Patil
I think this is because the prefix and the IPV6 used for the static NAT64 are in the same subnet
Can you try using a different /96 prefix
iashaan55
Community Member
Hello
I do not understand how R1 knows where to route the ICMPv6 reply as the subnet 3001::/96 is not routed in RIPng.
If you still have the lab, appreciate if you can show me a "show ipv6 route 3001::/96" and a " show ipv6 route 3001::A00:1" ?
Many thanks
Ashaan
perkin
Level 4
Level 4
so for this stateful NAT is more like PAT /NAT pool  while stateless is more similar NPT to IPV4 (is that still call NAT-PT?)
can anyone enlighten me if any difference between these "NAT64" and "IPV6 NAT"(NAT-PT) since I found both in the same document below
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/15-mt/nat-15-mt-book/iadnat64-stateless.html
perkin
Level 4
Level 4
in response IASHAAN55 question
that is because of the default route of RIPng
#<skipped>
