vita_user
Hallo,
I have a great problem with our time synchronization. In our network there are two switches Cisco 3750E (as coreswitch). One of them (first) has a default ntp (server external) but the other switch cannot sync the time from the first switch. The time from the second switch is after 15 minutes.
How can I sync this second switch with the first one? Which command can I use to sync a switch with another source?
#conf t
config#ntp server 192.168... ..
It does not work. The server is registered but not sync...
fyi:
#show ntp associations
         adress             ref clock   st   when   poll      reach
+~192.53.103.108      .PTB.       1    477    1024    377
* ~192.53.103.104      .PTB.       1    160    1024    377
Thanks for your help!
Best regards
Alex
