asofrani
Introduction
The purpose of this document is to demonstrate the Open Shortest Path First (OSPF) path selection behavior when a router receives both a Type-5 link-state advertisement (LSA) and a Type-7 LSA for a given external network. When redistribution is performed in a non-NSSA area, OSPF will inject a Type-5 LSA into the OSPF domain. Redistribution into an NSSA area creates a special type of LSA referred to as Type-7, which can only exist in an NSSA area.
Prerequisites
Refer to the network diagram in Figure 1 as you use this document:
In the network diagram, there is both a non-backbone area 1 and a NSSA area 50 connected to R1. R1 is an Area Border Router (ABR) connected to backbone area 0. Both R2 and R3 are responsible for redistributing the same prefix 192.0.2.100/32 into the OSPF domain.
Components Used
The information in this document is based on these software versions:
  • Cisco CSR1000V Version 16.4.1
Background Information
Cisco IOS-XE devices support RFC 3101 for external path calculation. RFC 1587 is obsoleted by RFC 3101 but RFC 1587-specific behavior can still be enabled through configuration. In Cisco IOS Release 15.1(2)S and later releases, the output of the show ip ospf command shows whether the device is using RFC 3101 or RFC 1587.
Below we have abstracts from both RFC 3101 and 1587. I have included only the sections relevant to path preference for external LSAs.
Abstract from RFC 3101 Section 2.5
(e) If the current LSA is functionally the same as an
 installed LSA (i.e., same destination, cost and non-zero
 forwarding address) then apply the following priorities in
 deciding which LSA is preferred:
1. A Type-7 LSA with the P-bit set.
2. A Type-5 LSA.
3. The LSA with the higher router ID.
Abstract from RFC 1587 Section 3.5
5. Otherwise, compare the cost of this new AS external path
         to the ones present in the table. Note that type-5 and
         type-7 routes are directly comparable. Type-1 external
         paths are always shorter than Type-2 external paths.
         Type-1 external paths are compared by looking at the sum
         of the distance to the forwarding address/ASBR and the
         advertised Type-1 paths (X+Y). Type-2 external paths are
         compared by looking at the advertised Type-2 metrics,
         and then if necessary, the distance to the forwarding
         address/ASBR.
         When a type-5 LSA and a type-7 LSA are found to have the
         same type and an equal distance, the following priorities
         apply (listed from highest to lowest) for breaking the tie.
                 a. Any type 5 LSA.
                 b. A type-7 LSA with the P-bit set and the forwarding
                    address non-zero.
                 c. Any other type-7 LSA.
         If the new path is shorter, it replaces the present paths
         in the routing table entry. If the new path is the same
         cost, it is added to the routing table entry's list of
         paths
Scenario 1
Network Diagram
In this scenario, we will be looking at what behaviour is observed when using RFC 3101 for external path calculation. We will be interested in prefix 192.0.2.100/32 that is redistributed on both R3 and R2.
 Type-1 LSA from R1 is in the below output:
R1#show ip ospf database router 1.1.1.1
            OSPF Router with ID (1.1.1.1) (Process ID 1)
                Router Link States (Area 0)
  LS age: 51
  Options: (No TOS-capability, DC)
  LS Type: Router Links
  Link State ID: 1.1.1.1
  Advertising Router: 1.1.1.1
  LS Seq Number: 80000007
  Checksum: 0x3BD6
  Length: 48
  Area Border Router
  AS Boundary Router
  Number of Links: 2
    Link connected to: another Router (point-to-point)
     (Link ID) Neighboring Router ID: 4.4.4.4
     (Link Data) Router Interface address: 192.168.14.1
      Number of MTID metrics: 0
       TOS 0 Metrics: 1
    Link connected to: a Stub Network
     (Link ID) Network/subnet number: 192.168.14.0
     (Link Data) Network Mask: 255.255.255.0
       TOS 0 Metrics: 1
                Router Link States (Area 1)
  LS age: 562
  LS Seq Number: 8000000C
  Checksum: 0xEC26
  Length: 48
  Area Border Router
  AS Boundary Router
  Number of Links: 2
     (Link ID) Neighboring Router ID: 3.3.3.3
     (Link Data) Router Interface address: 192.168.13.1
       TOS 0 Metrics: 1
     (Link ID) Network/subnet number: 192.168.13.0
       TOS 0 Metrics: 1
                Router Link States (Area 50)
  LS age: 562
  LS Seq Number: 80000012
  Checksum: 0x42CA
  Length: 48
  Area Border Router
  AS Boundary Router
  Number of Links: 2
     (Link ID) Neighboring Router ID: 2.2.2.2
     (Link Data) Router Interface address: 192.168.12.1
       TOS 0 Metrics: 1
     (Link ID) Network/subnet number: 192.168.12.0
       TOS 0 Metrics: 1
On R1 we have the following external LSAs in our database:
R1#show ip ospf database external
                Type-5 AS External Link States
  LS age: 706
  Options: (No TOS-capability, DC, Upward)
  LS Type: AS External Link
  Link State ID: 192.0.2.100 (External Network Number )
  LS Seq Number: 80000001
  Checksum: 0xE617
  Length: 36
  Network Mask: /32
        Metric Type: 2 (Larger than any link state path)
        MTID: 0
        Metric: 20
        Forward Address: 192.168.12.2
        External Route Tag: 0
  LS age: 600
  Advertising Router: 3.3.3.3
  LS Seq Number: 80000002
  Checksum: 0xBFAC
  Length: 36
  Network Mask: /32
        MTID: 0
        Metric: 20
        Forward Address: 0.0.0.0
R1#show ip ospf database nssa-external
                Type-7 AS External Link States (Area 50)
  LS age: 865
  Options: (No TOS-capability, Type 7/5 translation, DC, Upward)
  Advertising Router: 2.2.2.2
  Checksum: 0x32BC
  Length: 36
  Network Mask: /32
        MTID: 0
        Metric: 20
Now lets check what LSA is preferred on R1:
R1#show ip ospf rib 192.0.2.100
                Base Topology (MTID 0)
OSPF local RIB
Codes: * - Best, > - Installed in global RIB
LSA: type/LSID/originator
*>  192.0.2.100/32, NSSA2, cost 20, fwd cost 1, tag 0, area 50
     SPF Instance 38, age 00:04:51
      contributing LSA: 7/192.0.2.100/2.2.2.2 (area 50)
      contributing LSA: 5/192.0.2.100/3.3.3.3
     Flags: RIB, HiPrio, ViaFwAddr, IntraNonBB, NSSA P-bit
      via 192.168.12.2, GigabitEthernet1 label 1048578
       Flags: RIB
 As we can see in the above output, R1 prefers LSAs Type-7 from R2. This is because we are following RFC 3101, which has the following path calculation preference
2. A Type-5 LSA.
Note: Please be aware that the following path calculation preference is applicable if the current LSA is functionally the same as an installed LSA. We can verify that the forwarding metric for both LSAs are the same looking at Type-1 LSA of R1.
Since the Type-7 LSA was recieved with P-bit set we will prefer this LSA over other Type-5 LSAs.
Now if we clear the P-bit on NSSA Type-7 LSA from R2 we will see that we will prefer Type-5 LSA from R3.
Below i have included information regarding P-bit from RFC 3101:
Abstract from RFC 3101 Section 2.4
An NSSA internal AS boundary router must set the P-bit in the LSA
   header's option field of any Type-7 LSA whose network it wants
   advertised into the OSPF domain's full transit topology.  The LSAs of
   these networks must have a valid non-zero forwarding address.  If the
   P-bit is clear the LSA is not translated into a Type-5 LSA by NSSA
   border routers.
   When an NSSA border router originates both a Type-5 LSA and a Type-7
   LSA for the same network, then the P-bit must be clear in the Type-7
   LSA so that it isn't translated into a Type-5 LSA by another NSSA
   border router.
Before we proceed with clearing the P-bit on R2, here is output of type-7 LSA from R2
R2#show ip ospf database nssa-external
            OSPF Router with ID (2.2.2.2) (Process ID 1)
  LS age: 1215
  Checksum: 0x32BC
  Length: 36
  Network Mask: /32
        MTID: 0
        Metric: 20
The P-bit can be cleared when an NSSA border router originates both a Type-5 LSA and a Type-7 LSA for the same network.
  LS age: 44
  Options: (No TOS-capability, No Type 7/5 translation, DC, Upward)
  LS Seq Number: 80000003
  Checksum: 0xBFAD
  Length: 36
  Network Mask: /32
        MTID: 0
        Metric: 20
Here are some important characteristics about the above output mentioned below:
  • Bit P—This bit is used in order to tell the NSSA ABR whether to translate type 7 into type 5.
  • No Type 7/5 translation means bit P = 0.
  • Type 7/5 translation means bit P = 1.
  • If bit P = 0, then the NSSA ABR must not translate this LSA into Type 5. This happens when NSSA ASBR is also an NSSA ABR.
  • If bit P = 1, then the NSSA ABR must translate this type 7 LSA into a type 5 LSA. If there are multiple NSSA ABRs, the one with highest router ID.
 Now when we check on R1 we see that we prefer Type-5 over Type-7 LSA.
OSPF local RIB
*>  192.0.2.100/32, Ext2, cost 20, fwd cost 1, tag 0
     SPF Instance 39, age 00:03:32
     Flags: RIB, HiPrio, IntraNonBB
      via 192.168.13.3, GigabitEthernet2 label 1048578
       Flags: RIB
Scenario 2
Network Diagram
Figure 3
In this scenario, we will be looking at what behaviour is observed when using RFC 1587 for external path calculation. RFC 3101 compliance is automatically enabled on IOS-XE devices. To replace RFC 3101 compatibility with RFC 1587 compatibility for route selection in not-so-stubby area (NSSA) Area Border Routers (ABRs), use the compatible rfc1587 command in router configuration mode or address family configuration mode. To restore RFC 3101 compatibility, use the no form of this command.
We will be interested in prefix 192.0.2.100/32 which is redistributed on both R3 and R2. First we must enable RFC 1587 compatibility on R1
R1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R1(config)#router ospf 1
R1(config-router)#compatible rfc1587
R1#show ip ospf  | in RFC
 Supports NSSA (compatible with RFC 1587)
Now once we have enabled Compatibility RFC 1587 on R1 we can check what paths are in our database and what LSA is preferred:
  LS age: 115
  Checksum: 0xBDAD
  Length: 36
  Network Mask: /32
        MTID: 0
        Metric: 20
  LS age: 48
  LS Seq Number: 80000005
  Checksum: 0x2CBF
  Length: 36
  Network Mask: /32
        MTID: 0
        Metric: 20
OSPF local RIB
     SPF Instance 44, age 00:01:56
     Flags: RIB, HiPrio, IntraNonBB, PartialSPF
       Flags: RIB
 Note: In the above output, you might have also noticed that R1 is not translating Type-7 to Type-5, this is because only Type-7 routes that have been added to the routing table may be candidates for translation.
aung-thura
Frequent Visitor
Frequent Visitor
Thanks @asofrani. It is helpful to me.
But for RFC 3101, the last comparison_
I have also tested like below.
L0:6.6.6.0/24|---R12(ASBR)--area2(NSSA)--R13(ABR)--area1(NSSA)--R14(ASBR)---|L0:6.6.6.0/24
R14 router id is 14.14.14.14
R12 router id is 12.12.12.12
Also the forward address are same cost.
R13#sh ip ospf database nssa-external 6.6.6.0
                           OSPF Router with ID (10.0.123.13) (Process ID 1)
                                Type-7 AS External Link States (Area 1)
Routing Bit Set on this LSA in topology Base with MTID 0
LS age: 227
Link State ID: 6.6.6.0 (External Network Number )
Advertising Router: 14.14.14.14
Checksum: 0x5560
Length: 36
Network Mask: /24
MTID: 0
Metric: 20
Forward Address: 10.0.134.14
                                 Type-7 AS External Link States (Area 2)
LS age: 1109
Advertising Router: 12.12.12.12
Checksum: 0xE3E5
Length: 36
Network Mask: /24
MTID: 0
Metric: 20
Forward Address: 10.0.123.12
R13#sh ip route ospf
!omitted for brevity
6.0.0.0/24 is subnetted, 1 subnets
O N2 6.6.6.0 [110/20] via 10.0.134.14, 00:01:14, Ethernet0/1
                     [110/20] via 10.0.123.12, 00:02:15, Ethernet0/0
According to my test result, the router is installing two NSSA routes into the routing table and performing ECMP. So, I am not sure how the higher router id win the comparison according to RFC (3101). If you have any idea, please let me know.
ATR
asofrani
Hello @aung-thura,
I believe the above statement you are referencing from RFC 3101 helps us determine which LSA type is preferred. Once we have determined this we may, of course, perform ECMP. Since you have two type 7 LSAs they are both added into the OSPF RIB and FIB.
I hope the above helps.
Kind regards
Aleksandar Sofranic
aung-thura
Frequent Visitor
Frequent Visitor
Thanks asofrani.
gongya001
Level 5
Level 5
Can you post the diagrams ?
thanks !!
asofrani
@gongya001, I have updated the document with the network diagrams. 🙂
gongya001
Level 5
Level 5
thanks so much !!
