rmelumal
Community Member
Step 1:  Power OFF and Power ON the device
Step 2:  Hold mode button till u reach switch prompt
Step 3:  Once you reach switch mode, Give following commands
               switch: flash_init
               switch: load_helper
Step 4:  Give switch: dir flash: command to check the config.text file
               <config.text file contains the password>
Step 5:   Rename the config.text file to some other name like config.old
Step 6:   Enter command 'boot' and switch starts booting
Step 7:   After booting, set your new password from config mode.
Reference Link: https://www.youtube.com/watch?v=r88HmwQGd0s
