sharsaha
Latest version of Cisco Prime Cable Provisioning compatibility matrix attached here.
Rich R
@sharsaha did you mean PCP Compatibility Matrix in the title?
Do you want to provide some explanation/notes to go with this file?
sharsaha
Hi Rich, Yes that is correct. Thank you for the comments. I added notes mentioning the same.
