SunilKhanna
    Introduction
    OSPF External Routes (E2) are advertised into OSPF Autonomous System with a particular cost and the cost is not changed throughout the AS. The routes are learned via redistribution of other routing protocol or static route or a connected subnet. The router performing redistribution is the Autonomous System Border Router (ASBR). By default, all OSPF routes learned via redistribution are of E2 type.
    Redisribution of OSPF Routes (E1 or E2) into BGP can be performed via two ways, this document focus on E2 routes.
    a) Command " redistribute ospf 1 match external 2"
    b) Using Route-Map Match Statement "match route-type external type-2"
    Using Route Maps gives more felxibility to the user, as one can match the routes based on different criteria (access-list, tag).
    Prerequisite
    • Understanding of OSPF Routing Protocol
    • Understanding of Border Gateway Protocol (BGP)
    Background Summary
    In this document the focus is on route-map to match the E2 types routes and then redistributing them into other routing system. Three Routers, R1, R2 and R3 are connected via Serial Interface. Router R1 and R2 are participating in OSPF Area 0 while Router R2 and R3 are forming IBGP peering under AS 100.
    On R1, Loopback Interfaces (Lo 2 and Lo 3), are redsitributed in OSPF. A route-map "connected is configured" to match the specified interfaces and then redistributed via command "redictribute connected route-map connected". On router R2 these loopback prefixes are learned of type E2. On R2, a route-map (route-map E2OSPF in this document, see configuration on Router R2) is configured to match only the E2 type prefixes and redistribiuted into BGP system.
    Note: All configurations are tested on C3745 router operating on IOS verison 12.4(15)T14.
    Topology Diagram
    Configuration
    R1R2R3
    hostname R1
    ip cef
    no ip domain lookup
    interface Loopback0
    ip address 1.1.1.1 255.255.255.255
    interface Loopback2
    ip address 2.2.2.2 255.255.255.255
    interface Loopback3
    ip address 3.3.3.3 255.255.255.255
    interface Serial0/0
    ip address 10.12.12.1 255.255.255.252
    clock rate 2000000
    router ospf 10
    router-id 1.1.1.1
    log-adjacency-changes
    redistribute connected subnets route-map CONNECTED
    network 10.12.12.1 0.0.0.0 area 0
    route-map CONNECTED permit 10
    match interface Loopback2 Loopback3
    end
    hostname R2
    ip cef
    no ip domain lookup
    interface Loopback0
    ip address 22.22.22.22 255.255.255.255
    interface Serial0/0
    ip address 10.12.12.2 255.255.255.252
    clock rate 2000000
    interface Serial0/1
    ip address 192.23.23.1 255.255.255.252
    clock rate 2000000
    router ospf 10
    router-id 22.22.22.22
    network 10.12.12.2 0.0.0.0 area 0
    router bgp 100
    no synchronization
    bgp router-id 22.22.22.22
    bgp log-neighbor-changes
    network 192.23.23.1 mask 255.255.255.255
    redistribute ospf 10 route-map E2OSPF
    neighbor 192.23.23.2 remote-as 100
    neighbor 192.23.23.2 next-hop-self
    no auto-summary
    route-map E2OSPF permit 10
    end
    hostname R3
    ip cef
    no ip domain lookup
    interface Loopback0
    ip address 33.33.33.33 255.255.255.255
    interface Serial0/0
    ip address 192.23.23.2 255.255.255.252
    clock rate 2000000
    router bgp 100
    no synchronization
    bgp router-id 33.33.33.33
    network 192.23.23.2 mask 255.255.255.255
    neighbor 192.23.23.1 remote-as 100
    no auto-summary
    end
    Verification
    Command show ip route ospf
    Command show route-map {route-map name}
    Command show ip route BGP
    References
    Understanding Redistribution of OSPF Routes into BGP
    IP Routing: OSPF Configuration Guide 12.4
    IP Routing: BGP Configuration Guide 12.4
    Samer R. Saleem
    Level 4
    Level 4
    thanks for sharing
