on
04-30-2026
01:20 PM
- edited on
07-21-2026
02:00 PM
by
Tyler Langston
There are several methods for deploying the ThousandEyes Endpoint Agent. SCCM is a common, efficient approach for bulk deployment. However, in environments where the standard MSI package deployment is not feasible, a PowerShell script serves as an effective alternative. This script can be configured to include the necessary connection string, TCP driver, and browser extensions (Chrome, Edge) for the designated ThousandEyes account group.
Please note: This process is recorded here but not one that is officially supported.
Create the PowerShell script using the following code. (Make sure to use the .ps1 extension in the file format name)
# Variables
$InstallerPath = "<MSI PATH FILE>"
$LogPath = "<EXISTING FOLDER PATH FOR LOGS\ThousandEyesInstall.log>”
# This is the Account Group Connection String
$AccountToken = "<YOUR CONNECTION STRING>"
# Execution
# Do not modify below this line
# 1. Check if the installer exists
if (-not (Test-Path $InstallerPath)) {
Write-Error "Installer not found at: $InstallerPath"
exit 1
# 2. Build the arguments
# Note: Changed TOKEN to ACCOUNT_CONFIG and added ADDLOCAL features
$Arguments = @(
"/i `"$InstallerPath`"",
"ACCOUNT_CONFIG=`"$AccountToken`"",
"ADDLOCAL=`"ExtendedNetworkTestsSupport,IeExtension,ChromeExtension,EdgeExtension`"",
"/qn",
"/norestart",
"/l*v `"$LogPath`""
# 3. Start the MSI installation
try {
Write-Host "Starting Cisco ThousandEyes installation..."
$process = Start-Process "msiexec.exe" -ArgumentList $Arguments -Wait -PassThru
if ($process.ExitCode -eq 0 -or $process.ExitCode -eq 3010) {
Write-Host "Installation completed successfully (Exit Code: $($process.ExitCode))."
} else {
Write-Host "Installation failed with Exit Code: $($process.ExitCode)"
exit $process.ExitCode
} catch {
Write-Host "An error occurred during execution: $($_.Exception.Message)"
exit 1
Make sure to specify the correct variables in the code:
InstallerPath: Path location of the MSI installer (Endpoint agent MSI package)
LogPath: The EXISTING folder for the ThousandEyes logs to be created, example for windows machines: “C:\Windows\Temp\ThousandEyesInstall.log". Important log file to get the Product Code needed in next steps.
AccountToken: This is the connection string that will map the Endpoint Agent to the ThousandEyes account group. The connection string can be found in the ThousandEyes UI under: Endpoint Experience > Agent Settings > Add New Endpoint Agent > Connection String
We need to create the SCCM application to push the software with the PowerShell script.
Inside the Microsoft Configuration Manager and under software management > Applications. Click on “Create Application”.
Note: It is worth to mention that In SCCM, you do not upload files directly into the console (like you might with a web-based tool). Instead, SCCM uses a Content Source. A folder on a network share that the Site Server grabs the files from. e.x: \\Server\Share\CiscoThousandEyes
In the next wizard screen it will ask you for a name and the installation program like in below’s image.
powershell.exe -NoProfile -ExecutionPolicy Bypass -File "<Your powershell script File.ps1>" -InstallerFilePath "<Your Endpoint Agent File.msi>" -AccountConfig "<EPA Connection String>" -EnableChromeExtension -EnableEdgeExtension
After configuring these fields, click “Next” on this and the following summary screen. After finishing the application creation wizard, you will see the application listed like in below’s image.
Right click on the application and go to “properties” . We can see the multiple tabs, one of them is the “distribution settings” which is the process of moving the application’s source files (Powershell script and endpoint agent msi) from your site server to the Distribution Points (DPs).
This setting determines the order in which the Package Transfer Manager sends content to your Distribution Points. By default the content priority will be Medium, which is the the standard for most applications including ThousandEyes.
You can either automatically download the content when packages are assigned to the distribution points, or manually copy the content for this application to the distribution points. Whichever is best for your environment or deployment strategy.
The Detection method is important to verify the presence of the software in a particular machine using the correct MSI Product Code which it is the industry standard for reliability.
This clause is critical for your ThousandEyes deployment to Prevent Installation Loops.
SCCM checks the Windows Registry for that specific Product Code. If it finds it, it simply reports "Installed" and skips the execution.
Without a detection method, SCCM has no way of knowing the agent is already there. It will run your PowerShell script over and over again on every cycle, which wastes CPU and network bandwidth.
Since we are using a script and not the direct MSI file, you have to specify the product code by editting the clause and inserting the correct ThousandEyes Endpoint agent product code. This product code can be found in the ThousandEyesInstall.log file generated after the installation.
Log entry example:
MSI (s) (BC:BC) [14:55:12:667]: APPCOMPAT: looking for appcompat database entry with ProductCode '{XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXX}'.
You can also use the following powershell command to check the product code, example:
PS C:\Users\Alex > Get-ItemProperty HKLM:\Software\Microsoft\Windows\CurrentVersion\Uninstall\* | Where-Object {$_.DisplayName -like "*ThousandEyes*"} | Select-Object DisplayName, PSChildName
DisplayName PSChildName
ThousandEyes Endpoint Agent {XXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXX}
To add this product code, select Deployment Types under the ThousandEyes application Properties, Choose “edit”, and select “Detection Method”.
This is the section in which you can either modify or create a clause using the product ID taken from the previous step.
Under the content locations tab inside the ThousandEyes application properties, you will be able to see the Distribution points used for this application. In SCCM a distribution point is a server that acts as a local "warehouse" for your software files.
Its primary job is to store the content (like the ThousandEyes MSI and your PowerShell script) so that client computers can download them over the local network.
To add distribution points to the application you can select them by right clicking on the ThousandEyes application > Distribute Content, and then add the Distribution points you want, like in the following image.
The last step is to push the software.
1. Right click on the ThousandEyes application > “Deploy”, and select the collection of users or devices you want to deploy the software to by using the top-left dropdown.
2. Specify the settings to control this deployment.
Available: The application appears in the Software Center. The user decides if and when to install it.
Required: The application installs automatically without user intervention. (Recommended for ThousandEyes)
Click next and the installation wizard will ask you for additional details like: Scheduling the deployment to a specific time, or if you want to display notifications about the application in software center.
After configuring this options, click “done” and the deployment configuration will be completed. The deployment takes about 1 hour to start with no manual intervention. However you can trigger the deployment manually in a machine by going to the Windows Control panel item “Configuration Manager Properties” > Machine Policy Retrieval & Evaluation Cycle > “Run Now”
We hope this article has been informative and helpful for you in deploying Endpoint Agents via SCCM utilizing a PowerShell script.
Additional reference material for information about endpoint agent installation:
Installing Endpoint Agents
