ekhabaro
Introduction
This article describes typical problem with a design of the redundancy when OMP path selection is enforced on a vEdge device and not on the vSmart controller that can cause to unwanted results and loss of reachability to remote site in case of link failure even if backup path is available.
Topology and configuration
To understand the problem better, here is a simple topology diagram is provided that depicts the setup:Screen Shot 2018-10-17 at 14.02.56.png
- Site DC1 has TLOC colors "private1" and "biz-internet"
- Site DC2 has TLOC colors "private1" and "biz-internet"
- Site HQ has TLOC color "private1" only
- In DC1 and DC2 both colors are used for control connection to vSmart
Both DC sites (DC1 and DC2) are advertising the same network, 198.51.100.0/24.
In each site vEdge learns the router from the DC via some kind of dynamic routing protocol, e.g. BGP.
Each DC site tags the prefix with a different metric:
- At site DC1 vEdge set origin-metric 32
- At site DC2 vEdge set origin-metric 52
hostname site-id system-ip
DC1 21 10.100.0.21
DC2 41 10.100.0.41
HQ 100 10.100.0.100
vSmart 100 10.100.0.20
Problem
During normal operation:
- vSmart receives 198.51.100.0/24 from both DC1 and DC2:
vsmart1# show omp routes 198.51.100.0/24
Code:
C   -> chosen
I   -> installed
Red -> redistributed
Rej -> rejected
L   -> looped
R   -> resolved
S   -> stale
Ext -> extranet
Inv -> invalid
Stg -> staged
U   -> TLOC unresolved
                                            PATH                      ATTRIBUTE
VPN    PREFIX              FROM PEER        ID     LABEL    STATUS    TYPE       TLOC IP          COLOR            ENCAP  PREFERENCE
3      198.51.100.0/24       10.100.0.21      36     1003     C,R       installed  10.100.0.21      biz-internet     ipsec  -           <===== METRIC 32 (PREFERRED)
                           10.100.0.21      49     1003     C,R       installed  10.100.0.21      private1         ipsec  -           <===== METRIC 32 (PREFERRED)
                           10.100.0.41      36     1003     R         installed  10.100.0.41      biz-internet     ipsec  -           <===== METRIC 52
                           10.100.0.41      49     1003     R         installed  10.100.0.41      private1         ipsec  -           <===== METRIC 52
- vSmart advertises to HQ the route with destination DC1 (via private1 and biz-internet) because it has the lowest origin-metric as per OMP route selection criteria
vsmart1# show omp routes 198.51.100.0/24 vpn 3 detail
omp route entries for vpn 3 route 198.51.100.0/24
            RECEIVED FROM:                      <================= RECEIVED FROM vEDGE in DC1 in "biz-internet" color
peer            10.100.0.21
path-id         36
label           1003
status          C,R
loss-reason     not set
lost-to-peer    not set
lost-to-path-id not set
    Attributes:
     originator       10.100.0.21
     type             installed
     tloc             10.100.0.21, biz-internet, ipsec
     ultimate-tloc    not set
     domain-id        not set
     overlay-id        1
     site-id          21
     preference       not set
     tag              1000030021
     origin-proto     eBGP
     origin-metric    32
     as-path          "65001 65001 65001"
     unknown-attr-len not set
            RECEIVED FROM:                      <================= RECEIVED FROM vEDGE in DC1 in "private1" color
peer            10.100.0.21
path-id         49
label           1003
status          C,R
loss-reason     not set
    Attributes:
     type             installed
     tloc             10.100.0.21, private1, ipsec
     domain-id        not set
     overlay-id        1
     site-id          21
     preference       not set
     tag              1000030021
     origin-proto     eBGP
     origin-metric    32
            RECEIVED FROM:                      <================= RECEIVED FROM vEDGE in DC2 in "biz-internet" color
peer            10.100.0.41
path-id         36
label           1003
status          R
loss-reason     origin-metric
lost-to-peer    10.100.0.21
lost-to-path-id 49
    Attributes:
     originator       10.100.0.41
     type             installed
     tloc             10.100.0.41, biz-internet, ipsec
     domain-id        not set
     overlay-id        1
     site-id          41
     preference       not set
     tag              1000030041
     origin-proto     eBGP
     origin-metric    52
     as-path          "65001 65001 65001 65001 65001"
            RECEIVED FROM:                      <================= RECEIVED FROM vEDGE in DC2 in "private1" color
peer            10.100.0.41
path-id         49
label           1003
status          R
loss-reason     tloc-id
lost-to-peer    10.100.0.41
lost-to-path-id 36
    Attributes:
     type             installed
     tloc             10.100.0.41, private1, ipsec
     domain-id        not set
     overlay-id        1
     site-id          41
     preference       not set
     tag              1000030041
     origin-proto     eBGP
     origin-metric    52
            ADVERTISED TO:                        <================= WE ADVERTISE TO HQ vEdge ONLY BEST ROUTES WITH METRIC 32
peer    10.100.0.100
    Attributes:
     label            1003
     path-id          4410
     domain-id        not set
     site-id          21
     overlay-id        1
     preference       not set
     tag              1000030021
     origin-proto     eBGP
     origin-metric    32
    Attributes:
     label            1003
     path-id          4439
     domain-id        not set
     site-id          21
     overlay-id        1
     preference       not set
     tag              1000030021
     origin-proto     eBGP
     origin-metric    32
- HQ vEdge flags the route with TLOC "biz-internet" as "Inv,U" because this vEdge doesn't have TLOC biz-internet
- HQ vEdge flags the route with TLOC "private1" as "C,I,R" and installs the route
DC1 failure scenario:
- In failure scenario, DC1 vEdge uplink in color "private1" fails (interface goes in down state) while "biz-internet" stays up.
- vSmart receives 198.51.100.0/24 from DC1 (reachable only via biz-internet) and DC2 (biz-internet and private1)
- vSmart advertises to HQ vEdge routes to DC1 (via biz-internet) because DC1 has the lowest metric:
vsmart1# show omp routes 198.51.100.0/24 detail
            RECEIVED FROM:
peer            10.100.0.21
path-id         36
label           1003
status          C,R
loss-reason     not set
    Attributes:
     type             installed
     domain-id        not set
     overlay-id        1
     site-id          21
     preference       not set
     tag              1000030021
     origin-proto     eBGP
     origin-metric    32
            RECEIVED FROM:
peer            10.100.0.41
path-id         36
label           1003
status          R
lost-to-path-id 36
    Attributes:
     type             installed
     domain-id        not set
     overlay-id        1
     site-id          41
     preference       not set
     tag              1000030041
     origin-proto     eBGP
     origin-metric    52
            RECEIVED FROM:
peer            10.100.0.41
path-id         49
label           1003
status          R
loss-reason     tloc-id
lost-to-path-id 36
    Attributes:
     type             installed
     domain-id        not set
     overlay-id        1
     site-id          41
     preference       not set
     tag              1000030041
     origin-proto     eBGP
     origin-metric    52
            ADVERTISED TO:
peer    10.100.0.31
    Attributes:
     label            1003
     path-id          5906
     domain-id        not set
     site-id          21
     overlay-id        1
     preference       not set
     tag              1000030021
     origin-proto     eBGP
     origin-metric    32
            ADVERTISED TO:
peer    10.100.0.41
    Attributes:
     label            1003
     path-id          7689
     domain-id        not set
     site-id          21
     overlay-id        1
     preference       not set
     tag              1000030021
     origin-proto     eBGP
     origin-metric    32
            ADVERTISED TO:        <===== THIS IS WHAT WE ADVERTISE TO HQ SITE
peer    10.100.0.100
    Attributes:
     label            1003
     path-id          4410
     domain-id        not set
     site-id          21
     overlay-id        1
     preference       not set
     tag              1000030021
     origin-proto     eBGP
     origin-metric    32
- HQ vEdge flags the route with TLOC "biz-internet" as "Inv,U" because this vedge doesn't have TLOC biz-internet
The result is that HQ vEdge cannot reach 198.51.100.0/24.
Solution
vSmart could have sent the routes towards DC2 (with less prefered higher metric) and in that case HQ vEdge would  still reach the destination using the "private1" TLOC via DC2, which is still up:
VEDGE-HQ-1# show bfd sessions site-id 41
                                      SOURCE TLOC      REMOTE TLOC                                      DST PUBLIC                      DST PUBLIC         DETECT      TX
SYSTEM IP        SITE ID  STATE       COLOR            COLOR            SOURCE IP                       IP                              PORT        ENCAP  MULTIPLIER  INTERVAL(msec) UPTIME          TRANSITIONS
10.100.0.41      41       up          private1         private1         192.168.11.1                    192.168.41.1                    12406       ipsec  7           1000           12:04:02:25     0
But there is no route via "private1" TLOC via DC2 on HQ vEdge installed because vSmart has already selected biz-internet route with lower metric as the best path. vSmart does not advertise OMP routes with different metrics by default, hence does not let receiving vEdge device decide which path to take (and take into account available TLOCs and it's states). vSmart dosn't take into account TLOC colors available on remote device (HQ vEdge in our case) to which we are going to advertise route and does not take into account it's state because there is no such mechanism to control this.
This is inherited OMP corner case that can be seen in similar topology with iBGP route reflector and peering from physical interfaces addresses.
First solution option is to use  add-path like functionality (RFC7911) available in OMP and called "send-backup-paths" on vSmart:
omp
  send-backup-paths
It will advertise all available path so remote HQ vEdge will choose path based on TLOC availability.
Second solution option here will be to remove route-policy action "set metric" for corresponding prefix on DC1 and DC2 vEdges and then perform centralized route selection enforcement via vSmart control-policy as below for example:
policy
lists
site-list site_11
site-id 11
prefix-list PREFIX
ip-prefix 198.51.100.0/24
control-policy SET_PREF
sequence 10
match route
prefix-list PREFIX
site-id 21
action accept
set
preference 200
sequence 20
match route
prefix-list PREFIX
site-id 41
action accept
set
preference 100
default-action accept
apply-policy
site-list site_11
control-policy SET_PREF out
Here site-id 11 is the HQ vEdge and prefix-list PREFIX contains prefixes which we want to be preferred over one TLOC color or another.  Since now both OMP routes are on HQ vEdge, once vEdge can't reach biz-internet anymore, it will install a route via private1 in the RIB from it's OMP routes table.
