When I boot I get this message: *Mar  1 00:13:53.719: %C2600-4-SMARTINITDISABLE: Warning! You have disabled SMART INIT
and manually configured the amount of IO memory allocated. This is HIGHLY
discouraged on the Cisco 2600XM Series platforms as it may deprive the
system of memory necessary for normal operation. It is highly recommended
that SMART INIT not be disabled to ensure proper router operation.
How do I change smart init to enable?
shehzadtesleem
Guys;
I want to know why smat init goes disabled or how i can disable it.
