vita_user
Community Member
I'm working on Cisco-Network(with Coreswitch Cisco 3750E). Since two weeks the core switch has an utilization of 100% (every ten minutes). The nagios reports the following message: "cisco_load | CPU: 99 99 99 : 99 > 98".
In IOS command: 3750E#show proc cpu
result:
316     8864348    869362      10196 74.49% 77.95% 78.33%   0 SNMP ENGINE
Why the snmp has a load over 70%? Can you help me?
I take this information in a forum:
There are two probable causes for high CPU  utilization occuring in relation to Simple Network Management Protocol  (SNMP):
  1. Large route and/or ARP tables being polled by the NMS station
  2. Polling certain MIBs
How can I get the #show proc cpu histroy# in real time?
Best regards
podhillo
Level 4
Level 4
In the in case we need to reset the SNMP engine.
Following are the steps to do so:
get the output of 'sh run | in snmp' save it to a notepad and then do a 'no snmp-server' in the conf t mode.
then check for the output 'show proc cpu | in SNMP'
check the SNMP ENGINE would not be visible.
after a minute add the commands back in the configuration.
and then check and let me know if the CPU utilisation shows any improvement.
please let me know if this was helpful.
a.blankenburg
Visitor
it solved my Problem.
rendy.nugroho
Frequent Visitor
Frequent Visitor
I have the same issue as yours. Is there any solution beside reset the SNMP Engine? The solution that more 'safety'? because I have this issue on production device.
nabil oukaddi
Community Member
CPU utilization for five seconds: 99%/0%; one minute: 97%; five minutes: 73%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
391 84297255 1831084 46037 71.84% 69.81% 44.98% 0 SNMP ENGINE
162 295922131 46317956 6388 9.37% 9.58% 11.08% 0 Hulc LED Process
6 2947618 322409 9142 0.96% 0.18% 0.13% 0 Check heaps
132 7223210 1892101 3817 0.36% 0.40% 0.37% 0 hpm counter proc
168 27 98 275 0.36% 0.02% 0.00% 1 Virtual Exec
128 3175323 30924934 102 0.29% 0.33% 0.25% 0 hpm main process
173 2839940 377520 7522 0.17% 0.14% 0.13% 0 HQM Stack Proces
90 1163137 84452734 13 0.17% 0.14% 0.11% 0 RedEarth Tx Mana
91 2488074 84492946 29 0.17% 0.11% 0.09% 0 RedEarth Rx Mana
193 244965 982427 249 0.12% 0.04% 0.01% 0 CDP Protocol
220 2381807 21089678 112 0.12% 0.17% 0.13% 0 Spanning Tree
233 185700 1883445 98 0.12% 0.06% 0.03% 0 PI MATM Aging Pr
100 926369 9449167 98 0.12% 0.07% 0.05% 0 apm86xxx_enet_pr
361 1668 768 2171 0.12% 0.42% 0.31% 2 Virtual Exec
390 43891 322484 136 0.05% 0.00% 0.00% 0 PDU DISPATCHER
389 245407 1005125 244 0.05% 0.06% 0.06% 0 IP SNMP
207 102184 851006 120 0.05% 0.07% 0.06% 0 IP Input
174 1066840 755019 1412 0.05% 0.02% 0.04% 0 HRPC qos request
122 2394892 51184276 46 0.05% 0.05% 0.05% 0 HLFM address lea
19 7 9 777 0.00% 0.00% 0.00% 0 Entity MIB API
21 3665 377543 9 0.00% 0.00% 0.00% 0 IPC Event Notifi
20 0 1 0 0.00% 0.00% 0.00% 0 IFS Agent Manage
22 13982 1843113 7 0.00% 0.00% 0.00% 0 IPC Mcast Pendin
24 0 1 0 0.00% 0.00% 0.00% 0 IPC Session Serv
25 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
18 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
27 15895 1843112 8 0.00% 0.00% 0.00% 0 IPC Deferred Por
23 132 31519 4 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
26 18701 1843113 10 0.00% 0.00% 0.00% 0 IPC Periodic Tim
30 894 108110 8 0.00% 0.00% 0.00% 0 IPC Check Queue
31 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat RX Cont
32 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat TX Cont
33 2088 189229 11 0.00% 0.00% 0.00% 0 IPC Keep Alive M
34 5813 378071 15 0.00% 0.00% 0.00% 0 IPC Loadometer
35 63 6 10500 0.00% 0.00% 0.00% 0 PrstVbl
17 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
37 0 1 0 0.00% 0.00% 0.00% 0 Exception contro
38 454 194 2340 0.00% 0.00% 0.00% 0 crypto sw pk pro
28 0 1 0 0.00% 0.00% 0.00% 0 IPC Process leve
29 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat Manager
41 19715 1892101 10 0.00% 0.00% 0.00% 0 GraphIt
36 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
43 0 2 0 0.00% 0.00% 0.00% 0 SMART
44 0 2 0 0.00% 0.00% 0.00% 0 XML Proxy Client
45 0 1 0 0.00% 0.00% 0.00% 0 ARP Snoop
46 6481 1883620 3 0.00% 0.00% 0.00% 0 Dynamic ARP Insp
47 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
48 137358 2360278 58 0.00% 0.03% 0.01% 0 Net Background
roeizamir2934
Community Member
hi
i have SW version - WS-C3560X-24       15.0(1)SE3
after enabling SNMP THE cpu RISE TO 100%
i have tried the solution of sh run | in snmp' save it to a notepad and then do a 'no snmp-server' and enabling it again
and it didnt solve the issue
can you please advise what else can be done ?
Roei
