chipshot1971
Community Member
I currently have a login banner set on my routers.  The problem I'm having is that it only shows up after you enter in your user name and I would like it to show up before.  From what I can find Cisco docs. says it should show up before.  any suggestions on whats going on and how to correct it?
vasco2009
Community Member
banner login # Authorized
Personnel Only! Please enter your username and
password. #
Pronoy Dasgupta
Hey Edwin,
I think this might answer your questions:
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml#banners
Thanks and Regards
Pronoy
pompeychimes
Level 4
Level 4
Use "banner motd" instead.
Stephen Pearce
I've had problems using MOTD banner on 6500's before where it only came up after login. Changed to SSH version 2 and then came up ok before login.
