Jordan Rutherford
Summary
A very common method to authenticate with an API is to first utilize basic authentication credentials that get exchanged for an OAuth Bearer Token in a POST request, and then pass the Bearer Token into a subsequent GET request to query the target API for requested data.
This process can be accomplished using ThousandEyes' API Test in as little as 2 Steps. Step 1 sends a POST request using Basic Auth that returns a Bearer Token in a JSON object in the response body. Utilizing Post-Request Options, the JSON is parsed and the Bearer Token is saved as a variable that may be passed to Step 2 and any other subsequent steps.
Process
Test Configuration
  • Create an API Test
  • Configure the test’s network measurements as desired
  • Select "Configure Target API"
Step 1
  • Use POST method and configure API endpoint URL for access token generation
    • Set Authentication to "Basic"
    • Enter credentials to be used for Basic Authentication:
  • Configure Parameters, Headers, Body, and Assertion Rules as desired
  • Navigate to Post-Request Options
    • Deselect "Collect Response for this API step" to remove secrets from test results
    • Declare a variable to capture the OAuth token returned from the request and the JSON object to capture from. In this case "token" is the variable and "access_token" is the key that captures the token's value from the JSON response:
  • Select "Add Step" to proceed with the configuration of Step 2
Step 2
  • Use GET method and configure API endpoint URL to retrieve data
    • Set Authentication Type to "Bearer Token"
      • Enter "{{token}}" in the Bearer Token field to select the variable of "token", the variable menu will appear once "{{" is entered to confirm the variable is available to be selected:
    • Configure Parameters, Headers and Assertion Rules as desired
  • As a result, Bearer Authentication has succeeded and a JSON array of Cisco Routers is returned!
And that's all there is to it. If you experience any issues with this implementation please consider reaching out to us via chat - we're always happy to help!
Mike Gonzalez
Nice document (y)
