SunilKhanna
    Introduction
    Load balancing is the ability of a router to share the workload across redundant links to achieve optimal resource utilization.
    Requirements
    The document assumes an understanding of OSPF routing protocol.
    Background
    In this network topology, two routers R1 & R2 are connected via Fast Ethernet (Fa 1/0) and Serial (Se 2/0) interfaces. OSPF is the routing protocol configured and networks advertised are the loopback addresses of the two routers (Prefix 1.1.1.1/32 and 2.2.2.2/32).
    The document describes three scenarios, i.e
    • Scenario A: Default Behavior
    • Scenario B: Routes learned via redundant link (Serial 2/0)
    • Scenario C: Load Balancing Over two links
    Note: All configurations are tested in a lab environment on Cisco 7200 series router with IOS C7200-ADVIPSERVICESK9-M), Version 15.0(1).
    Topology Diagram
    Configuration: Scenario A (Default Behavior)
    By default, the advertsied prefixes (in this topology the Loopback Addresses) are learned through the Fast Ethernet interface as the metric compared to that of the serial interface is less.
    Router 1Router 2
    hostname R1
    ip cef
    interface Loopback0
    ip address 1.1.1.1 255.255.255.255
    interface FastEthernet1/0
    ip address 10.1.1.1 255.255.255.0
    ip ospf 1 area 0
    duplex auto
    speed auto
    interface Serial2/0
    ip address 172.12.12.1 255.255.255.0
    ip ospf 1 area 0
    serial restart-delay 0
    clock rate 72000
    router ospf 1
    router-id 1.1.1.1
    network 1.1.1.1 0.0.0.0 area 0
    end
    hostname R2
    ip cef
    interface Loopback0
    ip address 2.2.2.2 255.255.255.255
    ip address 10.1.1.2 255.255.255.0
    ip ospf 1 area 0
    duplex auto
    speed auto
    interface Serial2/0
    ip address 172.12.12.2 255.255.255.0
    ip ospf 1 area 0
    clock rate 72000
    router ospf 1
    router-id 2.2.2.2
    network 2.2.2.2 0.0.0.0 area 0
    end
    Verification
    The default cost of an Fast Ethernet interface is 1 by the formula 10(8)/Bandwidth (of an interface). The route 2.2.2.2 is known via the FastEthernet 1/0.
    Configuration: Scenario B (Giving preference to Serial Link)
    The cost of a link can be manipulated in order to learn routes from redundant link. In this scenario, we are changing the cost on Fast Ethernet to 100, so that the Serial Interface is prefered. The command is "ip ospf cost []".
    Router 1Router 2
    hostname R1
    ip cef
    interface Loopback0
    ip ospf 1 area 0
    ip ospf cost 100
    duplex auto
    speed auto
    interface Serial2/0
    ip ospf 1 area 0
    clock rate 72000
    router ospf 1
    router-id 1.1.1.1
    end
    hostname R2
    ip cef
    interface Loopback0
    ip ospf 1 area 0
    ip ospf cost 100
    duplex auto
    speed auto
    interface Serial2/0
    ip ospf 1 area 0
    clock rate 72000
    router ospf 1
    router-id 2.2.2.2
    end
    Verification
    Note: The prefix 2.2.2.2 is known via Serial 2/0 Interface with a metric of 65.
    Configuration: Scenarion C (Equal Cost Over Different Links)
    In this scenario, we are chaning the cost of an interface such that the two interface metrics are same.
    Router 1Router 2
    hostname R1
    ip cef
    interface Loopback0
    ip ospf 1 area 0
    ip ospf cost 64
    duplex auto
    speed auto
    interface Serial2/0
    ip ospf 1 area 0
    clock rate 72000
    router ospf 1
    router-id 1.1.1.1
    end
    hostname R2
    ip cef
    interface Loopback0
    ip ospf 1 area 0
    ip ospf cost 64
    duplex auto
    speed auto
    interface Serial2/0
    ip ospf 1 area 0
    clock rate 72000
    router ospf 1
    router-id 2.2.2.2
    end
    Verification
    Note: The prefix 2.2.2.2 is available via FastEthernet 1/0 and Serial 2/0 with equal metric of 65.
    References
    Cisco Support: OSPF
    IP Routing: OSPF Configuration Guide
    Cisco IOS IP Routing: OSPF Command Reference
    ben.laakso
    Level 4
    Level 4
    Hi Cisco Crew, your last two links under "References" are both dead.
