*Mar 1 00:01:28.592: %PLATFORM_IPC-3-COMMON: Init failed before IPC init
-Traceback= 16F4B68 15EA4D0 2926648 29266E0 1FE2584 1FE27F0 1BD366C 1BC9E40
*Mar 1 00:01:28.726: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
*Mar 1 00:01:28.944: hl2mcm_core_process: hl2mcm_install_hl2mcm_ctrl_entries() failed.
*Mar 1 00:01:28.944: %SYS-3-HARIKARI: Process HL2MCM top-level routine exited
*Mar 1 00:01:29.959: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlanCannot Get the number of ports in MAC notification
*Mar 1 00:01:30.412: %SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = ifs_read_until (header) / file = / code = 21 (Is a directory) / bytes transfered = -1
-Traceback= 117E394 117DFD0 1132374 1BD366C 1BC9E40
*Mar 1 00:01:32.081: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(55)SE12, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 28-Sep-17 02:29 by prod_rel_team
*Mar 1 00:01:32.174: Unable to open UDP socket on CMP_PORT
*Mar 1 00:01:32.174: %SYS-3-MGDTIMER: Running timer, init, timer = 3B64080. -Process= "Connection Mgr", ipl= 0, pid= 3
-Traceback= 291E258 291E3BC 291E4A8 1FA5108 1BD366C 1BC9E40
