Please provide United States-based groups with presenters who have U. S. English as a primary language. We had to rewind this vid several times at several points because the presenter had such a thick accent and was very difficult to understand.
The setup looks straight-forward and the video is pretty easy to understand. However, the actual routing step (ip route 0.0.0.0 0.0.0.0 200.1.1.2) is missing from the video. Including that and a better explaination of the routing would make this document and video much better.
I used Packet tracer to do the testing, however, the 'IP Routing" is not available in any switch in the Packet Tracer.
I do not have physical hardware available for the testing.
If we need this command "ip route 0.0.0.0 0.0.0.0 200.1.1.2", then do we have to have a router on the stub. if a router is needed, then why need layer 3 switch?
PS:
I find that need select Multi-Layer Switch in the Packet Tracer.
It is working now, no need "iproute 0.0.0.0 0.0.0.0 200.1.1.2" command, no need Router -on-Stick
you don't need a default route. he is showing inter-vlan routing not how to allow hosts to access the internet. Since the routes are connected C* there is not need for a default just to speak to each other.
i want to know how to manage trafic using policies.I mean how i can tell my SD-WAN to send for exemple ICMP by public-internet and as buckup in mpls, and send web trafic in mpls and as buckup in public-internet. Thank you for the help.
Repurposed a switch from a 3 member stack. #3 is being repurposed. Running IOS v16.12.04 Factory reset by pushing the Mode button 3 times to get into ROMMON, and followed procedures listed at https://community.cisco.com/t5/switching/c9300...
view more
Hi I have below doubts please someone help on this. 1. Why etherchannel configuration is not advisable for odd ports 2. is that possible to do etherchannel Ethernet and fiber together when both are in same speed. 3. Four links are in etherc...
view more
Hello, everyone, I have an RV082 router, but from a while back I've had problems with my network, some micros have lost Internet access, even access folders from the network, but don't browse, if I try to get a new ip through Windows solutions, I get a me...
view more
Q1. What is the best tool for log collection in cisco device(Switch, Router and ASA )? EPC, SPAN or other tools? Q2. As Huawei has #display diag command to collect all logs from the device. Is there any command in cisco device to collect all lo...
view more
