Unable to get CreateInterface API to work | NDFC
Adam Swindell
Hello. I am trying to use the API "/appcenter/cisco/ndfc/api/v1/lan-fabric/rest/globalInterface" to create a loopback interface.
API reference: API Reference (LAN) - Nexus Dashboard Fabric Controller API, Release 12.2.2 - Cisco DevNet
This is the JSON body I am trying to POST to the API.
  "policy": "int_loopback",
  "interfaceType": "INTERFACE_LOOPBACK",
  "interfaces": [
      "serialNumber": "22O2222022",
      "ifName": "Loopback4",
      "nvPairs": {
        "Interface VRF": "site_1_default_vrf",
        "Loopback IP": "10.242.1.2",
        "Route-Map TAG": "12345",
        "Interface Description": "site_1_default_vrf leaf loopback"
But then I get this error message
        "reportItemType": "ERROR",
        "message": "Interface Type is not valid",
        "entity": "BGW-2-SITE-1:Loopback4",
        "line": 0,
        "column": 0
I've tried all kinds of changes, and modifications to the JSON data but nothing makes any difference. Wondering if anyone can shed some light on this.
Thanks.
The error message "Interface Type is not valid" suggests that the API is complaining about the interfaceType field in your JSON payload, the API swagger doc uses a port channel as an example, but not explicitly list all possible values in this case the loopback. Can you try a GET request and see what the payload looks like for a loopback, i wonder if this is the same like
'INTERFACE_LOOPBACK_INTERNAL' but that is a guess
I took a shot at this based off this https://developer.cisco.com/docs/nexus-dashboard-fabric-controller/12-2-2/getting-started/#your-first-nexus-dashboard-fabric-controller-api-example guessing here again and wonder if using this and the nvpair gets closer to what you want.
  "policy": "int_loopback_host",
  "interfaceType": "INTERFACE_LOOPBACK_INTERNAL",
  "interfaces": [
      "serialNumber": "SDKT1234HD",
      "ifName": "Loopback0",
      "nvPairs": {
        "LOOPBACK0_IP_RANGE": "10.1.1.1/32",
        "ADMIN_STATE": "true",
        "DESC": "Loopback interface for testing",
        "MTU": "1500",
        "ENABLE_NETFLOW": "false"
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
