Nexus Dashboard
Nexus Dashboard incorporates Nexus Insights, Network Assurance, and Multi-Site Orchestrator, as well as seamless access to network controllers and third-party tools and cloud-based services.
Hi mate,Likely it sounds ridiculous, but we just changed DNS and NTP server therefore NTP and DNS configuration have to be edited to new DNS and NTP IP address. An issue occurred when edit DNS of Nexus dashboard insight and dashboard orchestrator als...
I am having issue with my VPC in NDFC Lab.Remove from interface group option under more is greyed out. when i go to policy and search the policy attached to the port channel. it gave me error.tried to delete the port channel member interfaces but sam...
Zarrar by • Frequent Visitor
  • 359 Views
  • 3 replies
I tried to configure SNMPv3 for the N9K switches, but I could only find the SNMP user template and could not find the SNMP group template.Could anyone advise on the correct template name? or how to configure it without freeform.
Ahmed Gamal by • Frequent Visitor
  • 956 Views
  • 4 replies
I'm migrating from MSO to NDO and have a few APIs that we use to monitor and configure things in MSO.Will those APIs continue to work after migrating to NDO, or do MSO and NDO have completely different APIs?
Forward by • Level 1
  • 373 Views
  • 1 replies
Is the NDO API backward compatible?I have two Nexus Dashboard deployments for different sites:Nexus Dashboard 3.2.1e (newer)Nexus Dashboard 2.1.2d (older)The following API works on the newer version but does not work on 2.1.2d:GET /mso/api/v1/nodesIs...
  • 379 Views
  • 1 replies
We are running into issues with ACI inbound management towards the Nexus Dashboard, because traffic to the VMM integration is also starting to flow through the inbound interface, while we want this to go over out-of-band. I believe the issue has been...
Hi, I am relatively new to NDFC. I have some Palo Alto firewalls that are setup like below. VXLAN SW1 E1/10 <-> Palo Alto E1/1  - Palo Alto E1/2 <-> VXLAN SW2 E1/10VXLAN SW1 E1/11 <-> Palo Alto E1/3  - Palo Alto E1/4 <-> VXLAN SW2 E1/11 When we do th...
kmelchior by • Level 2
  • 424 Views
  • 2 replies
  • 1 Helpful votes
