DCNM boots into emergency mode
Mkvts
We have had some issues with our Virtual Environment.
Our DCNM server (Single node) is now booting in Emergency mode.
is there any quick way to boot this in normal node? I couldn't find the information.
Mkvts
We have found a solution for this problem.
Cisco DCNM Release Notes, Release 11.3(1) - Guidelines and Limitations [Cisco Nexus Dashboard Fabric Controller] - Cisco
  • The DCNM installer creates a _deviceImage-0.iso in the DCNM VM folder and mounts the ISO permanently to the VM. If this ISO is removed or the CD/DVD is disconnected, the VM will not boot. The VM will enter Emergency Mode and prompt you with the message:Give root password for maintenance. If the VM is down, CD/DVD drive can be disconnected. However, after you power it up again, the VM will enter Emergency Mode and provide a prompt.
After a crash in our hypervisor the ISO was not mounted anymore.
