Deploy Nexus Dashboard - How to size Data Network subnet
gennaro.cullari
Good morning all,
I would ask you how to size Data Network.
If I'm going to deploy 3 nodes on VMWare site, do I need just a /29 subnet ?
And if i'm going to deploy other 3 nodes on another VMware site, can i size another another /29 subnet ?
Thank you.
roxadiaz
Hi Gennaro
The data network is used to bring up the ND cluster just consider how many nodes you will use. You can use the calculator to review the sizing of the cluster.
https://www.cisco.com/c/dam/en/us/td/docs/dcn/tools/nd-sizing/index.html
If you will create another cluster you can use another /29 subnet if you want. Just a consideration:
The Data interface is used too:
•Used for Apps to communicate with ACI Fabric Inband Mgmt or ACI Fabric Out-of-Band or DCNM Inband à needs to be routable
ND Data Interface IP subnet must be different from ACI INB IP subnet, when ND is directly connected to an ACI fabric
•Used for cluster internal communication: App and Service Network flows are tunneled between the ND nodes via VXLAN encapsulation managed by ND. MTU needed is 1500 bytes, between ND nodes.
I hope this helps
