04-24-2024 07:02 AM
want to move the vpc heartbeat connection of a N9K pair from a L2 switch to a direct cable.
To my understanding -as long as the peer link is up- a disruption of the heartbeat link should not affect any traffic to the connected hosts.
Is this correct? Or do I need a maintenance window for this?
Solved! Go to Solution.
04-25-2024 01:23 AM
as I mention before the traffic will not effect by keepalive down
but you need to reconfig it ASAP
MHM
04-24-2024 07:15 AM
There is nothing happened to traffic but you need to be fast'
And it better done this in maintenance window.
The keepalive is not only use for heartbeat but also for exchange mgmt/control traffic between two vpc NSK.
If you want I will make small lab test down keepalive and share details about interface and vpc status.
But I am sure it not effect.
MHM
04-24-2024 08:04 AM
04-25-2024 01:23 AM
MHM
04-25-2024 07:37 AM
Hi MHM
thanks for your prompt lab. It makes me confident that this change can be done (quickly) in an "out-of-office-hour"
Keep you informed when done
best regards
Frank
