SAN controller cannot be run in parallel to Fabric Controller or Fabric Discovery.
You cannot enable it cause probably you have fabrics and devices managed by the Fabric Controller.
If you are not using it remove all those entities, disable the fabric controller services and then you should be able to start the SAN Controller.
ADP
