Understanding the `~s` Break Signal Issue in Cisco Passwords: Risks an
Farshad Qhayati
Introduction
When working with Cisco devices (especially Nexus switches or routers with console access), you may encounter unexpected behavior if your password contains the sequence `~s`. This happens because Cisco interprets `~s` as a break signal —a special key combination used for debugging or accessing ROMMON.
Maybe you will see this message: 'Please press ~a to return to the active SUP console.'
In This article I explain:
- Why `~s` in passwords causes issues.
- How to avoid or mitigate the problem.
Why `~s` in Passwords Is Problematic
  1. `~s` as a Break Signal
- In Cisco console sessions, `~s` is a keyboard escape sequence that sends a hardware break signal.  When typed at the start of a line, it can:
  • Interrupt the login process.
  • Force the device into **ROMMON mode (for password recovery, or ..... ).
  • Terminate an ongoing command.
  1. When Does This Happen?
  • Mostly Console sessions (less in SSH/Telnet sessions).
  • If `~s` appears at the beginning or middel of a password input line
  • If typed too quickly (Cisco may misinterpret it as a break request).
How to Fix or Avoid the Issue
  1. Escape the `~` Character , But If your password must contain or includes `~s`:
  • Add a delay between `~` and `s` (e.g., type `~`, pause for 1 second or more, then `s`).
  • Enclose the password in quotes (if supported by the device):
                username admin
                password "abc~s123"
So, if you are locked out due to `~s`, as happened to me a few days ago, and you can't log in because `~s` causes an interruption:
  1. Re-enter the password slowly, ensuring that `~s` is not typed consecutively or in quick succession."
  2. But the previous method did not work for me. So, I divided the password into two parts: from the beginning of the password up to the character `~`, and from the character `s` to the end of the password. I then copied and pasted each part separately into the CLI in two steps. By doing this, I was able to log in to the system, and as my first action, I changed the password. Like this:
Password `Pass~sWord`
Part 1: `Pass~`
Part 2: `sWord`
If you’ve encountered this issue, share your experience below!
0 Replies 0
