Adding NFVO bundle in running NSO
Dear All
I have NSO running as ubuntu VM and want to add Cisco NFVO bundle into it.
As defined in nfvo.pdf,
"After installing the bundle in a running system, the packages has to be reloaded. This can be done in the
CLI."
But how to install bundle in running NSO system?
After unzip of ncs-4.7.1-tailf-etsi-rel2-nfvo-project-3.5.0.tar.gz, I got the following:
ubuntu@ubuntu1604:~/nso-4.7/packages/neds/ncs-4.7.1-tailf-etsi-rel2-nfvo-project-3.5.0$ ls -lrt
total 32
-rw-r--r-- 1 ubuntu ubuntu 726 Nov 19 09:11 project-meta-data.xml
drwxrwxr-x 2 ubuntu ubuntu 4096 Nov 19 09:11 packages
drwxrwxr-x 2 ubuntu ubuntu 4096 Nov 19 09:11 init_data
-rw-r--r-- 1 ubuntu ubuntu 12653 Nov 19 09:11 CHANGES
drwxrwxr-x 2 ubuntu ubuntu 4096 Nov 19 09:11 doc
Now how to proceed further to add these packages in running NSO is no where mentioned.
Pls help.
Rgds
Satish
frjansso
Hi!
If you look in the packages directory, you'll see a number of packages (some of which are examples). Copy the following packages to your NSO packages directory:
esc
If you want resource orchestration:
tailf-etsi-rel2-nfvo-ro and tailf-etsi-rel2-nfvo-ro-os
If you want UI:
tailf-etsi-rel2-nfvo-ui
Cheers,
Fredrik
frjansso
Hi!
esc
If you want UI:
Cheers,
Fredrik
Thanks Fredrik for the update.
I already got it resolved after troubleshooting.
Rgds
Satish
