Affirmed Networks Netconf NED error
oharel
I generated a NETCONF NED using YANG files from Affirmed networks, yet when I try to sync-from, I'm getting the following error:
info Device lab-affirmed does not advertise any known YANG modules
The trace looks like this:
>>>>out 27-Aug-2018::12:37:17.611 device=lab-affirmed
<?xml version="1.0" encoding="UTF-8"?>
<hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<capabilities><capability>urn:ietf:params:netconf:base:1.0</capability><capability>urn:ietf:params:netconf:base:1.1</capability></capabilities>
</hello>
>>>>out 27-Aug-2018::12:37:17.612 device=lab-affirmed
EOM
<<<<in 27-Aug-2018::12:37:17.699 device=lab-affirmed
<capabilities>
<capability>urn:ietf:params:netconf:capability:candidate:1.0</capability>
<capability>urn:ietf:params:netconf:capability:confirmed-commit:1.0</capability>
<capability>urn:ietf:params:netconf:capability:confirmed-commit:1.1</capability>
<capability>urn:ietf:params:netconf:capability:xpath:1.0</capability>
<capability>urn:ietf:params:netconf:capability:validate:1.0</capability>
<capability>urn:ietf:params:netconf:capability:validate:1.1</capability>
<capability>urn:ietf:params:netconf:capability:rollback-on-error:1.0</capability>
<capability>http://tail-f.com/ns/netconf/with-defaults/1.0</capability>
<capability>http://tail-f.com/ns/netconf/actions/1.0</capability>
<capability>urn:ietf:params:netconf:capability:with-defaults:1.0?basic-mode=explicit&amp;also-supported=report-all-tagged</capability>
<capability>urn:ietf:params:xml:ns:yang:ietf-netconf-with-defaults?revision=2011-06-01&amp;module=ietf-netconf-with-defaults</capability>
<capability>http://affirmednetworks.com/ns/yang/affirmed?module=affirmed&amp;revision=2015-11-12</capability>
<capability>http://affirmednetworks.com/ns/yang/alarms?module=alarms&amp;revision=2015-04-16</capability>
<capability>http://affirmednetworks.com/ns/yang/arp?module=arp&amp;revision=2011-07-14</capability>
<capability>http://affirmednetworks.com/ns/yang/calea?module=calea&amp;revision=2015-12-15</capability>
<capability>http://affirmednetworks.com/ns/yang/chassis?module=chassis&amp;revision=2013-06-12</capability>
<capability>http://affirmednetworks.com/ns/yang/cluster?module=cluster&amp;revision=2013-03-23</capability>
<capability>http://affirmednetworks.com/ns/yang/contentDefines?module=contentDefines&amp;revision=2011-03-13</capability>
<capability>http://affirmednetworks.com/ns/yang/contentStatsDefines?module=contentStatsDefines&amp;revision=2011-03-13</capability>
<capability>http://affirmednetworks.com/ns/yang/datapath?module=datapath&amp;revision=2016-07-29</capability>
<capability>http://affirmednetworks.com/ns/yang/dataplaneStats?module=dataplaneStats&amp;revision=2014-04-09</capability>
<capability>http://affirmednetworks.com/ns/yang/datarecord?module=datarecord&amp;revision=2015-03-04</capability>
<capability>http://affirmednetworks.com/ns/yang/debug?module=debug&amp;revision=2010-12-15</capability>
<capability>http://affirmednetworks.com/ns/yang/dpiStatsDefines?module=dpiStatsDefines&amp;revision=2012-06-20</capability>
<capability>http://affirmednetworks.com/ns/yang/extstorage?module=extstorage&amp;revision=2010-12-15</capability>
<capability>http://affirmednetworks.com/ns/yang/fm?module=fm&amp;revision=2013-11-14</capability>
<capability>http://affirmednetworks.com/ns/yang/geored?module=geored</capability>
<capability>http://affirmednetworks.com/ns/yang/grid?module=grid</capability>
<capability>http://affirmednetworks.com/ns/yang/httpProxyStatsDefines?module=httpProxyStatsDefines&amp;revision=2015-03-26</capability>
<capability>http://affirmednetworks.com/ns/yang/httpServerStatsDefines?module=httpServerStatsDefines&amp;revision=2014-09-10</capability>
<capability>http://affirmednetworks.com/ns/yang/im?module=im&amp;revision=2010-12-15</capability>
<capability>http://affirmednetworks.com/ns/yang/infrastructure?module=infrastructure&amp;revision=2016-07-03</capability>
<capability>http://affirmednetworks.com/ns/yang/ipdatapath?module=ipdatapath&amp;revision=2016-04-20</capability>
<capability>http://affirmednetworks.com/ns/yang/ipprotocols?module=ipprotocols&amp;revision=2016-12-27</capability>
<capability>http://affirmednetworks.com/ns/yang/license?module=license&amp;revision=2015-11-02</capability>
<capability>http://affirmednetworks.com/ns/yang/networkcontext?module=networkcontext&amp;revision=2014-09-15</capability>
<capability>http://affirmednetworks.com/ns/yang/networkingprofiles?module=networkingprofiles&amp;revision=2015-09-04</capability>
<capability>http://affirmednetworks.com/ns/yang/node?module=node</capability>
<capability>http://affirmednetworks.com/ns/yang/perfstatmgmt?module=perfstatmgmt&amp;revision=2014-11-25</capability>
<capability>http://affirmednetworks.com/ns/yang/personality?module=personality&amp;revision=2014-04-07</capability>
<capability>http://affirmednetworks.com/ns/yang/pki?module=pki&amp;revision=2016-02-25</capability>
<capability>http://affirmednetworks.com/ns/yang/routing?module=routing&amp;revision=2011-11-15</capability>
<capability>http://affirmednetworks.com/ns/yang/ruleProfiles?module=ruleProfiles</capability>
<capability>http://affirmednetworks.com/ns/yang/security?module=security&amp;revision=2016-06-27</capability>
<capability>http://affirmednetworks.com/ns/yang/serviceconstruct?module=serviceconstruct&amp;revision=2017-02-20</capability>
<capability>http://affirmednetworks.com/ns/yang/services?module=services&amp;revision=2015-05-20</capability>
<capability>http://affirmednetworks.com/ns/yang/sipStatsDefines?module=sipStatsDefines&amp;revision=2016-07-29</capability>
<capability>http://affirmednetworks.com/ns/yang/snmp?module=snmp&amp;revision=2014-11-07</capability>
<capability>http://affirmednetworks.com/ns/yang/subscriber?module=subscriber&amp;revision=2013-11-13</capability>
<capability>http://affirmednetworks.com/ns/yang/system?module=system&amp;revision=2014-09-29</capability>
<capability>http://affirmednetworks.com/ns/yang/systemStatsDefines?module=systemStatsDefines&amp;revision=2011-07-12</capability>
<capability>http://affirmednetworks.com/ns/yang/test?module=test&amp;revision=2015-04-14</capability>
<capability>http://affirmednetworks.com/ns/yang/thresholdDefines?module=thresholdDefines&amp;revision=2012-05-14</capability>
<capability>http://affirmednetworks.com/ns/yang/userAccess?module=userAccess&amp;revision=2014-11-04</capability>
<capability>http://affirmednetworks.com/ns/yang/vtap?module=vtap&amp;revision=2015-10-13</capability>
<capability>http://affirmednetworks.com/ns/yang/workflow?module=workflow&amp;revision=2013-07-26</capability>
<capability>http://affirmednetworks.com/ns/yang/zone?module=zone&amp;revision=2016-01-19</capability>
<capability>http://tail-f.com/ns/aaa/1.1?module=tailf-aaa&amp;revision=2011-09-22</capability>
<capability>http://tail-f.com/ns/mibs/IANAifType-MIB/201205170000Z?module=IANAifType-MIB&amp;revision=2012-05-17</capability>
<capability>http://tail-f.com/ns/mibs/IF-MIB/200006140000Z?module=IF-MIB&amp;revision=2000-06-14</capability>
<capability>http://tail-f.com/ns/mibs/IPV6-TC/199812010000Z?module=IPV6-TC&amp;revision=1998-12-01</capability>
<capability>http://tail-f.com/ns/mibs/SNMP-COMMUNITY-MIB/200308060000Z?module=SNMP-COMMUNITY-MIB&amp;revision=2003-08-06</capability>
<capability>http://tail-f.com/ns/mibs/SNMP-FRAMEWORK-MIB/200210140000Z?module=SNMP-FRAMEWORK-MIB&amp;revision=2002-10-14</capability>
<capability>http://tail-f.com/ns/mibs/SNMP-MPD-MIB/200210140000Z?module=SNMP-MPD-MIB&amp;revision=2002-10-14</capability>
<capability>http://tail-f.com/ns/mibs/SNMP-NOTIFICATION-MIB/200210140000Z?module=SNMP-NOTIFICATION-MIB&amp;revision=2002-10-14</capability>
<capability>http://tail-f.com/ns/mibs/SNMP-TARGET-MIB/200210140000Z?module=SNMP-TARGET-MIB&amp;revision=2002-10-14</capability>
<capability>http://tail-f.com/ns/mibs/SNMP-USER-BASED-SM-MIB/200210160000Z?module=SNMP-USER-BASED-SM-MIB&amp;revision=2002-10-16</capability>
<capability>http://tail-f.com/ns/mibs/SNMP-VIEW-BASED-ACM-MIB/200210160000Z?module=SNMP-VIEW-BASED-ACM-MIB&amp;revision=2002-10-16</capability>
<capability>http://tail-f.com/ns/mibs/SNMPv2-MIB/200210160000Z?module=SNMPv2-MIB&amp;revision=2002-10-16</capability>
<capability>http://tail-f.com/ns/mibs/SNMPv2-SMI/1.0?module=SNMPv2-SMI</capability>
<capability>http://tail-f.com/ns/mibs/SNMPv2-TC/1.0?module=SNMPv2-TC</capability>
<capability>http://tail-f.com/ns/mibs/TRANSPORT-ADDRESS-MIB/200211010000Z?module=TRANSPORT-ADDRESS-MIB&amp;revision=2002-11-01</capability>
<capability>urn:ietf:params:xml:ns:yang:ietf-inet-types?module=ietf-inet-types&amp;revision=2013-07-15</capability>
<capability>urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring?module=ietf-netconf-monitoring&amp;revision=2010-10-04</capability>
<capability>urn:ietf:params:xml:ns:yang:ietf-netconf-notifications?module=ietf-netconf-notifications&amp;revision=2012-02-06</capability>
<capability>urn:ietf:params:xml:ns:yang:ietf-yang-types?module=ietf-yang-types&amp;revision=2013-07-15</capability>
</capabilities>
<session-id>251262</session-id></hello>]]>]]>
>>>>out 27-Aug-2018::12:37:17.761 device=lab-affirmed session-id=251262
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="1">
<close-session/></rpc>
EOM
>>>>out 27-Aug-2018::12:37:17.762 device=lab-affirmed session-id=251262 NCS close
Is there a missing configuration on the devices / anything I'm missing?
Any advice is greatly appreciated,
Ohad
Jan Lindblad
This was because the NED wasn't properly built.
