applyTransParams question
sm000x
Level 5
Level 5
Maapi.commitQueueResult is deprecated and we should use applyTransParams.
I need help on how to use applyTransParams.
I have the following code:
CommitParams cp = new CommitParams();
cp.setCommitQueueSync();
cp.setNoOverwrite();
CommitQueueResult result = (CommitQueueResult)maapi.applyTransParams(th, false, cp);
For service create and delete, the code works fine.
However, when I do a change on the service with zero-delta (which means no change at all), I got the following error:
com.tailf.maapi.ApplyResult cannot be cast to com.tailf.maapi.CommitQueueResult
I have to use the deprecated Maapi.commitQueueResult, which works fine.
Does anyone have the same issue?
THX
sm000x
hazad
The applyTransParams() method returns a CommitQueueResult object only if a commit through the commit queue was requested:
https://pubhub.devnetcloud.com/media/nso-api-6.2/docs/java/com/tailf/maapi/Maapi.html#applyTransParams(int,boolean,com.tailf.maapi.CommitParams)
In your case you get an ApplyResult object returned, since the zero-delta commit is not applying anything to the queue. So you would need to verify that the object returned by applyTransParams is an instance of CommitQueueResult, before casting it.
hazad
Hi, Hazad:
Thank you so much. This is really helpful.
THX
sm000x
