Backup and restore router config using nso via netconf
kkuruvad
I have a use case where i have access to 2022 port and 8080 port of nso.  I need to backup the config of routers to a machine by using these ports.  I also need to replace the config of router using the backed up configs.
The preference would be to store the configs in plain text rather than xml.  It is not mandatory though.
Also please let me know how i can run this command that is run from ncs_cli using netconf:
devices device 192.168.123.11 live-status cisco-ios-xr-stats:exec show version
0 Replies 0
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
