Build Netconf ned for nxos
Hello dear,
I'm trying to buid netconf net for nxos.
I have clone : https://github.com/YangModels/yang.git
and make :
ncs-make-package --netconf-ned ../yang/vendor/cisco/nx/9.3-7/ nxos-9kv-9.3.7-nc
But I have too many error on make clean all such as:
yang/openconfig-bfd.yang:508: error: the node is config, but refers to a non-config node 'type' defined at yang/openconfig-interfaces.yang:293
yang/openconfig-if-aggregate.yang:103: warning: The XPath expression references an undefined node: the node 'lag-type' from module 'openconfig-if-aggregate' (in node 'member' in module 'openconfig-if-aggregate' from 'openconfig-if-aggregate') is not found
Your help will be appreciate.
regards
0 Replies 0
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
