cisco-iosxr-cli-7.18 NSO NED error-info LOAD_PACKAGE[com.tailf.packag
Fayyazii
I have NSO 5.3 working on EVE as docker and i have added additional NED cisco-iosxr-cli-7.18 to it. When i reload packages i get below failure / error logs.
Any idea where is the issue
admin@ncs# packages reload
>>> System upgrade is starting.
>>> Sessions in configure mode must exit to operational mode.
>>> No configuration changes can be performed until upgrade has completed.
>>> System upgrade has completed successfully.
reload-result {
package cisco-ios-cli-3.8
result true
reload-result {
package cisco-ios-cli-6.42
result false
info LOAD_PACKAGE[com.tailf.packages.ned.ios.IOSDp][com.tailf.packages.ned.ios.IOSNedCli]
reload-result {
package cisco-iosxr-cli-7.18
result false
info LOAD_PACKAGE[com.tailf.packages.ned.iosxr.IosxrNedCli]
admin@ncs# show packages package oper-status
packages package cisco-ios-cli-3.8
oper-status up
packages package cisco-ios-cli-6.42
oper-status program-code-error
oper-status error-info LOAD_PACKAGE[com.tailf.packages.ned.ios.IOSDp][com.tailf.packages.ned.ios.IOSNedCli]
packages package cisco-iosxr-cli-7.18
oper-status error-info LOAD_PACKAGE[com.tailf.packages.ned.iosxr.IosxrNedCli]
hniska
Check what the ncs-java-vm.log says.
