Cisco NX-OS 'switchport' default command - probably again
rslaski
Guys,
I've searched this forum for config differences between Cisco NX-OS device and what NED thinks about it, especially regarding default commands, and most of the replies were around "you have to live with it". But any chances to get the problem below solved?
Before applying port configuration in a service, to ensure the port in in a switchport mode (not in a routed mode), I apply the following configuration:
result-xml {
    local-node {
        data <devices xmlns="http://tail-f.com/ns/ncs">
                <device>
                  <name>NX_LEAF111</name>
                  <config>
                    <interface xmlns="http://tail-f.com/ned/cisco-nx">
                      <Ethernet>
                        <name>1/39</name>
                        <enable>
                          <switchport>true</switchport>
                        </enable>
So the whole thing equivalent to '(config-if)# switchport' is inside the following tags:
<enable>
</enable>
And as such, that part has also been put into a resulting service config, so it is there after the commit:
rslaski@ncs# show running-config devices device NX_LEAF111 config nx:interface Ethernet 1/39 | display xml
<config xmlns="http://tail-f.com/ns/config/1.0">
  <device>
      <config>
      <Ethernet refcounter="2"  backpointer="[ /TMPL:TMPL/TMPL:AC[TMPL:name='rsl1'] ]" >
        <name>1/39</name>
        <enable>
          <switchport refcounter="1" >true</switchport>
        </enable>
        <switchport>
          <mode refcounter="1" >access</mode>
          <access>
            <vlan refcounter="1" >71</vlan>
          </access>
        </switchport>
      </Ethernet>
      </interface>
      </config>
  </device>
  </devices>
</config>
The problem is that 'switchport' is a default setting on the platform, so after applying sync-from, it now missing from the config:
  <device>
      <config>
        <name>1/39</name>
        <switchport>
          <access>
          </access>
        </switchport>
      </Ethernet>
      </interface>
      </config>
  </device>
  </devices>
</config>
And now also the service complains about missing part on the device:
rslaski@ncs# TMPL AC rsl1 check-sync
in-sync false
rslaski@ncs# TMPL AC rsl1 check-sync outformat xml
result-xml {
    local-node {
                <device>
                  <config>
                      <Ethernet>
                        <name>1/39</name>
                        <enable>
                        </enable>
                      </Ethernet>
                      <Ethernet>
                        <name>1/71</name>
                        <enable>
                        </enable>
                      </Ethernet>
                      <Ethernet>
                        <name>1/73</name>
                        <enable>
                        </enable>
                      </Ethernet>
                    </interface>
                  </config>
                </device>
              </devices>
The impact is that my notrhbound system will constantly complain about service non-compliance, and will keep on re-deploying the service periodically.
vleijon
I am a little bit on thin ice here, but I would look into the ned settings. I think doing something like
devices device nx0 ned-settings cisco-nx-meta:cisco-nx system-interface-defaults handling auto
might be a good start, but we have a number of options available here.
vleijon
Can you try a
devices device NX_LEAF111 compare-config
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
