Connect a Netconf device to NSO behind a Cisco CLI router
PatrickPec78
Hello guys,
I'm pretty new to NSO, and I want to know if it is possible to configure a netconf router with NSO but this router is behind a router which is directly connected to NSO. Or does NSO require a direct connection ?
Example :
NSO --> |CLI router| ---> |Netconf router|
192.168.1.10    192.168.1.1/24                     192.168.10.10/24
The Netconf router is an IR1101.
If it is possible, can you explain to me briefly how to do it, because I didn't find anything on google about this ?
Thanks by advance.
rogaglia
I believe that what you want is to use the router in the middle as a "SSH proxy" to access the final destination. The idea of proxy is available for CLI NEDs but I do not believe for generic NETCONF devices (although it could be a good features to request).
One alternative is to use SSH tunnels and setup your NETCONF session via this tunnel. One example of SSH guide: https://www.ssh.com/ssh/tunneling/example
Roque
rogaglia
Roque
Hi Roque,
Thank you for your answer, I will try this !
A final question : is it possible to configure both devices at the same time (the CLI router and the Netconf router) following the architecture I gave ?
Yes, it is possible but using two device names (same IP different NED-IDs).
admin@ncs# show devices list
NAME ADDRESS DESCRIPTION NED ID ADMIN STATE
xr-cli 10.58.244.21 - cisco-iosxr-cli-7.19 unlocked
xr-netconf 10.58.244.21 - cisco-ncs55a1-01-nc-1.0 unlocked
admin@ncs#
This also means that your devices will generally be out-of-sync, but you should know how to manage that (partial-sync-from, no-overwrite or everything in the toolbox).
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
