Database is locked for writing. Locked by session
dhaparamm
Hi I am facing an issue while automate gnmi operation.
Error Trace:
grpc._channel._InactiveRpcError: <_InactiveRpcError of RPC that terminated with:
status = StatusCode.UNAVAILABLE
 "Database is locked for writing. Please retry: the configuration database is locked by session 18 yang_mgmt_infra tcp (system from 127.0.0.1) on since XXXXXX
 %GENIE-ERROR: IOS-XE YANG Infrastructure. Additional info: locked"
 %GENIE-ERROR: debug_error_string = "{"created":"@1660193967.406907508","description":"Error received from peer ipv4:ip:port","file":"src/core/lib/surface/call.cc","file_line":966,"grpc_message":"Database is locked for writing. Please retry: the configuration database is locked by session 18 yang_mgmt_infra tcp (system from 127.0.0.1) on since 2022-08-07 03:41:28\n IOS-XE YANG Infrastructure. Additional info: locked","grpc_status":14}"
%GENIE-ERROR: ERROR: Database is locked for writing. Please retry: the configuration database is locked by session 18 yang_mgmt_infra tcp (system from 127.0.0.1) on since 2022-08-07 03:41:28
%GENIE-ERROR: IOS-XE YANG Infrastructure. Additional info: locked.
Anyone have any idea on this?
u.avsec
I'm not sure this is an NSO subject. Or are you doing some fancy gNMI stuff with NSO?
The error showing that the database is locked for editing because it is locked by session 18.
I am automating GNMI with python code.
