Default NED Loading Failure of cisco-iosxr-cli-3.5 in NSO 5.3
Fayyazii
Hello team,
I am using NSO 5.3 and default packages were L2VPN & cisco-ios-cli-3.8.
I tried to copy ios-xr-cli-3.5 from nso-5.3/packages/neds to /home/NSO/ncs-run/packages/ and then in admin mode i reloaded packages to see ios-xr addtional package too
I got error : *** ALARM package-load-failure: LOAD_PACKAGE[com.tailf.packages.ned.iosxr.IosxrNedCli]
and in admin@ncs# show packages package oper-status i get error of IOS-XR NEDs.
packages package L2VPN
oper-status up
packages package cisco-ios-cli-3.8
oper-status up
packages package cisco-iosxr-cli-3.0
oper-status program-code-error
oper-status error-info LOAD_PACKAGE[com.tailf.packages.ned.iosxr.IosxrNedCli]
packages package cisco-iosxr-cli-3.5
admin@ncs#
root@NSO:/home/NSO/ncs-run/packages# ls
L2VPN cisco-ios-cli-3.8 cisco-iosxr-cli-3.5
root@NSO:/home/NSO/ncs-run/packages# ncs_cli -C -u admin
admin connected from 127.0.0.1 using console on NSO
admin@ncs# packages reload force
>>> System upgrade is starting.
>>> Sessions in configure mode must exit to operational mode.
>>> No configuration changes can be performed until upgrade has completed.
>>> System upgrade has completed successfully.
reload-result {
package L2VPN
result true
reload-result {
result true
reload-result {
result false
Does any one knows why its giving this failure/error and how i can fix them?
Nabsch
Hello ,
You need to check ncs-java-vm.log
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
