Delay the ssh and netconf connections
sutrehan
We have a requirement where we do not want to expose the NSO external connectivity till some basic initial config is done.
We are using NETCONF and ssh for external connectivity. WebUi is disabled.
Is it possible to to disable these transport at init time and later enable them via some config once the basic initialisation is done ?
Sumit
vleijon
Yes. You can disable interfaces in ncs.conf and use ncs –reload to re-read ncs.conf at a later time. You can also sometimes use the start phases of NSO, but that is a more special case.
vleijon
Thanks for the response.
Other than changing the ncs.conf, Is it configurable via some CLI or some internal tail NETCONF yang model as well ?
The phases can be controlled through the api, but not the detailed configuration I think.
