deref doesn't work in rpc
kuiliu
Hi Guys,
I was trying to create rpc, one leaf of input was defined with path of deref. I can get compile successful however the dereferenced path won't work there. Does anyone has run into the same issue?
rogaglia
There was a bug that was fixed last year. Just make sure you are using the latest NSO version or else please provide some information on what is not working for you.
Roque
Hi Rogaglia,
I'm working on ncs-4.7, I tried the same group in the service, deref works, but when it is applied in rpc, what I'm getting for xpath log is
get_elem(/allocate-id/id-pool-instance) = not_found
the part of yang for rpc is
grouping id-alloco-rpc-request {
leaf id-pool-instance {
// mandatory true;
type leafref {
path "/rm:resource-manager/rm:id-allocator/rm:pool-instance/rm:instance-name";
list query-path-args {
when "../id-pool-instance";
key query-name;
leaf query-name {
type leafref {
path "deref(../../id-pool-instance)/../existing-query/query-name";
leaf-list args {
type string;
//allocation rpc
rpc allocate-id {
tailf:actionpoint allocate-id-point;
input {
uses id-alloco-rpc-request;
output {
leaf allocted-id {
type string;
