Does anybody have an example of an action developed in python that calls upon a service?
gfreire
I am trying to code an action in python that grabs certain variables from devices and then creates a service based on those variables. I already have the service's yang and xml template produced and I can create the service manually. However, I'm having some trouble calling it via nso action. My action returns the output but doesn't seem to actually push anything into NSO.
I was wondering if someone has a project developed where this kind of scenario happens. I'd be much obliged if you could share it with me.
Hiro Takahashi
Hi Gabriel,
Following is a sample code to create a new service instance from NSO action.
In this model, a new instance for a service model called "aclservice" is created with four variables (device, aclname, aclnum and aclentry).
class EnableAction(Action):
    @Action.action
    def cb_action(self, uinfo, name, kp, input, output):
        self.log.info('action name: ', name)
        # get instance name
        self.instance_name = str(kp).split("{")[1].split("}")[0]
        self.log.info('action key path: ', self.instance_name)
        self.uinfo=uinfo
        self.kp=kp
        with ncs.maapi.single_write_trans(self.uinfo.username, self.uinfo.context) as t:
            root = ncs.maagic.get_root(t)
            # get service path
            service = ncs.maagic.cd(root, self.kp)
            # create a new instance of aclservice
            aclservice = root.aclservice.create(self.instance_name)
            aclservice.device = service.device
            aclservice.aclname = service.aclname
            aclservice.aclnum = service.aclnum
            aclservice.aclentry = service.aclentry
            t.apply()
Hope this helps.
Best regards,
Hiro
Hiro Takahashi
Hi Gabriel,
    @Action.action
        # get instance name
        self.uinfo=uinfo
        self.kp=kp
            # get service path
            t.apply()
Hope this helps.
Best regards,
Hiro
Thank you so much for the help, that was exactly what I was looking for! I adapted it a bit to my specific context and it's working perfectly.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
