Dry-run for yang-patch operation
tcragg1
I am experimenting with using the RFC8072 YANG Patch method to make changes to device configurations through NSO, and was trying to perform a dry-run to view the expected results of the operation. However, while sending the dry-run query parameter prevented the changes from being pushed to the network device, it only returned the following message, and not a dry-run of the changes:
 <yang-patch-status xmlns="urn:ietf:params:xml:ns:yang:ietf-yang-patch">
   <patch-id>test-patch</patch-id>
   <ok/>
* Connection #0 to host localhost left intact
 </yang-patch-status>
Is there a way to view the actual dry-run for a YANG patch operation in NSO (version 5.2.0.1)?
rogaglia
You would need to upgrade your NSO,
In 5.3.2/5.2.1 CHANGE file, I see:
- restconf: Parameter dry-run did not work for YANG Patch requests, but
with this fix it does work.
rogaglia
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
