Enable clustering
Shantha Kumar Selvaraj
Hi All,
I’m trying to add 2 nodes for now into clustering(x.cisco.com, y.cisco.com)   on z.cisco.com(Cluster MoM)
  1. 1. Made sure ncs.conf has ssh port 2022 set to true on client node
  2. 2. Authgroup mapping set to use same-user/same-pass.Not using a generic credential.
  3. 3. The logged in use on MoM cluster exists on all client nodes
  4. 4. Firewall is disabled
But it doesn’t look like cluster is receiving updates from client nodes,Am I missing anything,Appreciate any guidance
At MoM cluster(z.cisco.com)
ncs@ncs# show running-config cluster
cluster remote-node x.cisco.com
address   X.X.X.X
port      2022
ssh host-key ssh-rsa
  key-data "AAAAB3NzaC1yc2EAAAADAQABAAABAQDPAadlS80uGB2UY2D+edS3bo/b+IKRumax85TMd/py\n4VcyDcvN+RsihKxLWre+kHUNS1IDzF8fLX6f86WBdC+CMlmCc4UqSwzEjAttJH5zM71h0xfe\nkAZLDvQXdO1gimt48We0ubguMRO3QsMXA5/oOlCmz98DKjcIAGFl8HI7125VSgRSakb4jRYA\nvOTs7ZkYSsN0jy0TnccZGGxU93hoEtoGYhYi3DgsXGF5EjrBvQQDW7+ifuVMvX4Ooi6Fbjep\nHgYxf6+VMNQCR7qEbeZH3t33gwWgvmvPftyVj6djKpEpxF9OKJcAMCoAKEwwEBsgiOsI3fYB\nwDBT4jmlebZh"
ssh host-key-verification none
authgroup nwsclust
cluster remote-node y.cisco.com
address   y.y.y.y
port      2022
authgroup nwsclust
cluster authgroup nwsclust
default-map same-user
default-map same-pass
  same-user
  same-pass
show cluster
LAST   RECEIVED
NAME NAME  STATUS  EVENT  NOTIFICATIONS  NAME
x.cisco.com
y.cisco.com
rogaglia
Hi Shantha,
Any reason why you want to enable clustering?
Our current recommended architecture to scale NSO deployment is LSA (Layared Services Architecture) and not clustering.
Roque
rogaglia
Hi Shantha,
Roque
Thanks  for the response Roque
Our current immediate requirement is  to get the Manager of Manager view from one instance.
Yet to explore LSA approach.
