GET ISIS configuration in python script
Hello Team,
I'd like to get isis interface configuration in my python part.
I'm trying the following code with ipython
import ncs.maapi as maapi
import ncs.maagic as maagic
m= maapi.Maapi()
m.start_user_session('admin', 'test_context')
t= m.start_write_trans()
root= maagic.get_root(t)
router = root.devices.device['ROUTER']
 router.config.cisco_ios_xr__router.isis.tag
isis = router.config.cisco_ios_xr__router.isis
the problem is that, the object "router.config.cisco_ios_xr__router.isis" has no methods or properties  to get ISIS informations.
Your help will be appreciate.
regards.
0 Replies 0
