How can I enable https for REST?
anuragb
I would like to know how can I enable https for my REST calls? I enabled tls for Webui. As it uses JSON RPC, I can't find a way to make REST over HTTPS work.
Thx
-A
jvikman
If you enabled HTTPS for the Webui, then REST should be available over HTTPS as well.
Is the REST interface available without HTTPS? There is a separate setting for REST/RESTCONF which you need to set as well.
