How to build a NETCONF NED without ietf-netconf-monitoring
Scarfido
I'm currently trying to build a NED for a NETCONF device (thought it would be a good exercice) but I'm stuck because the device doesn't have the ietf-netconf-monitoring capabilty and netconf-ned-builder can't pull the model off the device.
Fortunately, I have all the YANG models (a blend of vendor specifics and standards ones) and I'm trying to put the together inside a NED. I've imitated the folder structure of a NED build by netconf-ned-builder (put all my models in ./src/yang, created a package-meta-data.xml.in file, created 2 yang file in ./src, etc...) and now I'm stuck on the Makefile. I have very little experience writing those and I'm struggling to adapt the ones from other NEDs and examples.
Is there a Makefile that I can use ? Or maybe a nice set of ncsc parameters ?
Scarfido
So, after trial and error, I've managed to get something to work.
The directory structure I have is (before any building) :
myned-nc-1.0/
└── src
    ├── Makefile
    ├── package-meta-data.xml.in
    └── yang
        ├── mymodel.yang
        └── myothermodel.yang
My Makefile (heavely based on the one from the junos NED) :
all: fxs
.PHONY: all
# Include standard NCS examples build definitions and rules
include $(NCS_DIR)/src/ncs/build/include.ncs.mk
NCSC_DEVICE_DIR = ./ncsc-out
src=$(wildcard yang/*.yang)
NFXS = ncsc-out/modules/fxs
FXS = $(SRC:yang/%.yang=../load-dir/%.fxs)
DIRS = ncsc-out ncsc-out/modules $(NFXS) ../load-dir
NED_ID_ARG = $(shell [ -x ${NCS_DIR}/support/ned-ncs-ned-id-arg ] && \
               ${NCS_DIR}/support/ned-ncs-ned-id-arg package-meta-data.xml.in)
fxs: $(DIRS) ../package-meta-data.xml $(FXS)
.PHONY: fxs
$(DIRS):
	mkdir -p $@
../package-meta-data.xml: package-meta-data.xml.in
	#ned-id built by: support/ned-make-package-meta-data"
	rm -rf $@
	if [ -x ${NCS_DIR}/support/ned-make-package-meta-data ]; then \
	    ${NCS_DIR}/support/ned-make-package-meta-data $<;         \
	else                                                          \
	    cp $< $@;                                                 \
	fi
	chmod -w $@
$(NFXS)/%.fxs: yang/%.yang
	rm -f $@ || true
	mkdir -p $(NCSC_DEVICE_DIR)
	$(NCSC) --use-description                   \
		--ncs-compile-module $<             \
		--ncs-device-dir $(NCSC_DEVICE_DIR) \
		--ncs-skip-statistics               \
		--ncs-device-type netconf           \
		$(NED_ID_ARG) | 2>&1                \
	  grep -v 'has no actionpoint' || true
../load-dir/%.fxs: $(NFXS)/%.fxs
	rm -f $@
	ln -s ../src/$< $@
.PRECIOUS: $(NFXS)/%.fxs
clean:
	rm -rf $(DIRS)
	rm -rf ../package-meta-data.xml
	rm -rf ./*.yang
.PHONY: clean
And my package-meta-data.xml.in
<ncs-package xmlns="http://tail-f.com/ns/ncs-packages">
  <name>myned</name>
  <package-version>1.0</package-version>
  <description>NED for my devices</description>
  <ncs-min-version>5.7</ncs-min-version>
  <component>
    <name>mydevice</name>
    <ned>
      <netconf/>
      <device>
        <vendor>Me</vendor>
      </device>
    </ned>
  </component>
</ncs-package>
Scarfido
myned-nc-1.0/
└── src
    ├── Makefile
    └── yang
        ├── mymodel.yang
all: fxs
.PHONY: all
.PHONY: fxs
$(DIRS):
	mkdir -p $@
	rm -rf $@
	else                                                          \
	    cp $< $@;                                                 \
	fi
	chmod -w $@
	rm -f $@ || true
	rm -f $@
	ln -s ../src/$< $@
clean:
	rm -rf $(DIRS)
	rm -rf ./*.yang
.PHONY: clean
  <name>myned</name>
  <component>
    <ned>
      <netconf/>
      <device>
        <vendor>Me</vendor>
      </device>
    </ned>
  </component>
</ncs-package>
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
