How to connect to device that requires jump host?
bcaloger
Hey guys !
The title says it all, I'd like to connect to a gate-way that requires a jump-host, any ideas on how to set this up on NSO
Hiro Takahashi
Yes, that is possible. But it might depend on NED though.
Please take a look at following IOS example.
[topology]
NSO ----> (192.168.0.1) jump server ----> (10.0.0.1) IE4000_1 End Device
[Config]
admin@ncs# show running-config devices device Router1
address   192.168.0.1    << IP address of jump server
authgroup IOS
device-type cli ned-id cisco-ios
device-type cli protocol telnet
ned-settings cisco-ios-proxy-settings remote-connection telnet
ned-settings cisco-ios-proxy-settings remote-address 10.0.0.1  << IP address of Router1
ned-settings cisco-ios-proxy-settings remote-port 23
ned-settings cisco-ios-proxy-settings proxy-prompt .*#   << Prompt of jump server
ned-settings cisco-ios-proxy-settings remote-prompt .*#  << Prompt of Router1
ned-settings cisco-ios-proxy-settings remote-name cisco
ned-settings cisco-ios-proxy-settings remote-password cisco
ned-settings cisco-ios-proxy-settings remote-secondary-password cisco
state admin-state unlocked
Best regards,
Hiro
Hiro Takahashi
[topology]
[Config]
authgroup IOS
Best regards,
Hiro
Bruno,
See if this helps:  NED Operation over a Terminal Server
Best,
Scott
sujmurth
Can we have similar settings for
device-type {
    netconf {
        ned-id netconf;
Dont see settings on ned to provide proxy settings
admin@ncs% set devices device CSP1 ned-settings use-
Possible completions:
  use-confirmed-commit  - Control usage of confirmed commit
  use-junos-rollback    - If set to true use device rollback as a revert strategy.
  use-private-candidate - Control usage of the private candidate
  use-startup           - Control usage of the startup datastore
  use-transaction-id    - Control usage of fetching the transaction id
  use-validate          - Control usage of validate
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
