How to create one or multiple loopback interfaces without python code
I want to create as many loopbacks as defined, like 1 till 10, how can I accomplish that with YANG and XML, for instance in a  foreach loop, without code.
leaf loopback_amount {
tailf:info "Amount of loopbacks";
type uint32 {
range "1..10";
mandatory true;
<interface xmlns="urn:ios">
<Loopback>
<name>{/int_name}</name>
<ip-vrf>
<ip>
<vrf>
<forwarding>{/vrf_id}</forwarding>
</vrf>
</ip>
</ip-vrf>
<ip>
<address>
<primary>
<address>10.1.1.</ip_add></address>
<mask>255.255.255.255</mask>
</primary>
</address>
</ip>
</Loopback>
yfherzog
Where do you plan to take the ip from?
yfherzog
from the yang file. and later from external ipam
