how to disable check sync when ned commit configuration to device
jinlliu
Hi Experts:
There are some devices(APIC, Openstack, CPNR) which not only managed by NSO but also others
so nso will manipulate such devices fail as out of sync error
also check sync will slow performance
we want to disable check sync to these devices,  are there any solutions for this ?
hniska
Either
admin@ncs% set devices device ce0 out-of-sync-commit-behaviour
Possible completions:
accept reject
out-of-sync-commit-behaviour - Specifies the behaviour of a commit operation involving a device that is out of sync with NCS.
Or
admin@ncs% commit no-out-of-sync-check
or
admin@ncs% commit no-overwrite
thanks a lot!
In my understanding, set out-of-sync-commit-behaviour  accept,  will just ignore out of check,
but it still will do check sync, then it will cost some performance
the second option:commit no-out-of-sync-check  seems work
but our service code didn;t know how to commit no-out-of-sync-check when apply templates
do you know how to acheve this from service model code perspective ?
thanks again!
'but our service code didn;t know how to commit no-out-of-sync-check when apply templates'
The 'no-out-of-sync-check' is not associated with a service model or modification via code/template, it is a commit flag applied to the transaction.
In the case of cli, you make your changes and then make the commit using the flag as Hakan has stated:
For Northbound interfaces (e.g. REST) where the commit is inferred from the request the no-out-of-sync-check commit flag must be attached to the URI:
curl -v -X PUT -u admin:admin --header "Content-Type:application/vnd.yang.data+xml" http://localhost:8080/api/running/devices/device/j0/config/configuration/system/host-name/?no-out-of-sync-check -d "<host-name>NEW-HOSTNAME</host-name>”
-Larry
sorry, commit no-out-of-sync-check ----> Commit even if out of sync
it seems still do check sync bot ignore, what we really need is skip check sync
Below cli seems work, but no sure what's use-transaction-id about, any side affect will be cause
devices device default_openstack_vim ned-settings use-transaction-id false
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
