How to globally hide sync-to operation with NACM?
JimBoucher
Hi, I am trying to hide the use of the sync-to functionality in the webui-one interface (at least) using NSO 5.2.0.3.
Hiding "devices sync-to" is easy.
<cmdrule xmlns="http://tail-f.com/yang/acm">
<name>c_devices_syncto</name>
<command>devices sync-to</command>
<action>deny</action>
</cmdrule>
<name>j_devices_syncto</name>
<command>request devices sync-to</command>
</cmdrule>
The problem is with denying sync-to for a specific device. I have tried a dozen options and the Admin Guide does not give any cmdrule examples beyond the trivial no-list case.  Can you point me in the right direct? None of these work:
<command>devices device '$DEVICE' sync-to</command>
<command>devices device $DEVICE sync-to</command>
<command>devices device sync-to</command>
<command>sync-to</command>
<command>devices device '[a-z]*' sync-to</command>
<command>/devices/device[name='$DEVICE']/sync-to</command>
And so on.  Thanks in advance for your help!
Jim
ADDED:
I have also tried using rule and a path. Here is my test config (that isn't working) using the rule approach:
admin@ncs# show running-config nacm
nacm enable-nacm true
nacm read-default permit
nacm write-default permit
nacm exec-default deny
nacm groups group admin
user-name [ admin private system ]
gid 1000
nacm groups group ncsadmin
user-name [ nsoadmin private ]
gid 1500
nacm groups group ncsoper
user-name [ oper public ]
gid 2000
nacm groups group oper
nacm rule-list admin
group [ admin ]
rule any-access
action permit
cmdrule any-command
action permit
log-if-permit
nacm rule-list any-group
group [ * ]
rule tailf-aaa-password-change
module-name tailf-aaa
path /aaa/authentication/users/user[name='$USER']/change-password
access-operations read,exec
action permit
rule tailf-aaa-user
path /user[name='$USER']
access-operations create,read,update,delete
action permit
rule tailf-webui-user
module-name tailf-webui
path /webui/data-stores/user-profile[username='$USER']
action permit
cmdrule c-logout
command logout
action deny
cmdrule j-logout
command "request system logout"
action deny
nacm rule-list ncsadmin
group [ ncsadmin ]
rule a_devices_read
module-name tailf-ncs
path /ncs:devices
action permit
rule a_devices_device_read
path /ncs:devices/device[name='$DEVICE']
action permit
rule a_devices_device_syncto
path /ncs:devices/device[name='$DEVICE']/sync-to
action deny
rule a_devices_syncto
path /ncs:devices/sync-to
action deny
rule any-access
action permit
cmdrule c-logout
command logout
action deny
log-if-permit
cmdrule j-logout
action deny
log-if-permit
cmdrule any-command
action permit
log-if-permit
nacm rule-list ncsoper
group [ ncsoper oper ]
rule tailf-aaa-user
action permit
action permit
rule tailf-aaa-alluser
path /user
action deny
rule tailf-aaa-aaa
path /aaa
action deny
rule nacm
module-name ietf-netconf-acm
path /
action deny
rule a_devices_read
path /ncs:devices
action permit
action permit
rule a_devices_device_syncto2
access-operations exec
action deny
rule a_devices_syncto2
action deny
rule read-only
path /
action permit
cmdrule c-logout
command logout
action deny
log-if-permit
cmdrule j-logout
action deny
log-if-permit
cmdrule any-command
action permit
log-if-permit
nacm cmd-read-default deny
nacm cmd-exec-default deny
2 Accepted Solutions
I figured it out. Thanks for clarifying that I had to use rule instead of cmdrule. At this point, I am assuming anything for a YANG Model is done with rule and only Cisco  Tailf CLI extension commands should be done with cmdrule. Please let me know if this is incorrect.
group [ ncsadmin ]
path /ncs:devices/device/sync-to
action deny
Jim
Hi Jim,
So the command needs to be a valid NSO CLI command - which isn't a linux-like syntax, so wildcarding and regex you are perhaps used to will likely not work here.
In your example:
NSO CLI cannot handle the '[a-z]*,
The device name, which this value represents, can be an individual device name (xr-0), a range of 'like' device names (xr-0..10), all devices of a prefix (xr-*), or 'all' devices (*).
Examples (all devices are netsims, therefor the same addr):
testuser@ncs% show devices device ios-0 address | tab
address 127.0.0.1;
testuser@ncs% show devices device xr-0..1 address | tab
NAME ADDRESS
xr-0 127.0.0.1
xr-1 127.0.0.1
testuser@ncs% show devices device xr-* address | tab
NAME ADDRESS
xr-0 127.0.0.1
xr-1 127.0.0.1
testuser@ncs% show devices device * address | tab
NAME ADDRESS
ios-0 127.0.0.1
ios-1 127.0.0.1
j-0 127.0.0.1
j-1 127.0.0.1
xr-0 127.0.0.1
xr-1 127.0.0.1
That said, by trial I have found that the cmdrule will not work when the command string contains the '*' wildcard.
I suspect that the '*' on the command line gets expanded prior to comparing it against the cmdrule string and does not match - just speculation.
So, the cmd will work as expected when the command string contains a single device name or a range of like devices.
So, I think you are prudent in pursuing the 'rule' to deny execution of the sync-to.
10 Replies 10
JimBoucher
Here is an example of the not-working command rules approach I am working with.
gid 1000
gid 1500
gid 2000
group [ admin ]
rule any-access
action permit
cmdrule any-command
action permit
log-if-permit
group [ * ]
action permit
rule tailf-aaa-user
action permit
action permit
cmdrule c-logout
command logout
action deny
cmdrule j-logout
action deny
group [ ncsadmin ]
rule any-access
action permit
cmdrule c_devices_syncto
command "devices sync-to"
action deny
log-if-permit
cmdrule c_device_syncto
command "devices device '$DEVICE' sync-to"
action deny
log-if-permit
cmdrule j_devices_syncto
command "request devices sync-to"
action deny
log-if-permit
cmdrule j_device_syncto
command "request devices device '$DEVICE' sync-to"
action deny
log-if-permit
cmdrule c-logout
command logout
action deny
log-if-permit
cmdrule j-logout
action deny
log-if-permit
cmdrule any-command
action permit
log-if-permit
rule tailf-aaa-user
action permit
action permit
path /user
action deny
rule tailf-aaa-aaa
path /aaa
action deny
rule nacm
path /
action deny
rule read-only
path /
action permit
action deny
log-if-permit
action deny
log-if-permit
action deny
log-if-permit
action deny
log-if-permit
cmdrule c-logout
command logout
action deny
log-if-permit
cmdrule j-logout
action deny
log-if-permit
cmdrule any-command
action permit
log-if-permit
This is working for me:
nacm rule-list oper
group [ oper ]
rule oper-sync-to
path /ncs:devices/ncs:sync-to
action deny
log-if-permit
Note that "access-operation = exec" should be used for acitons and rpcs.
The example you gave is for "devices sync-to" which is the example I showed working in cmdrule form above.  Can you provide a rule example that works for "devices device * sync-to"?
Jim
group [ ncsadmin ]
action deny
Jim
Jim,
To try to clarify the difference between NACM 'cmdrule' and 'rule'.
The definition of 'cmdrule' (from yang model, tailf-acm.yang):
description
"One command access control rule. Command rules control access
to CLI commands and Web UI functions.
So the cmdrule will permit/deny depending on the explicit matching of the rule's command string and  the command entered into the cli (it does not limit access to a node or sub-nodes of the cdb model) - nothing is implied from the rule, example denying a command for a range of devices would not deny the command for each of the devices:
admin@ncs% show nacm rule-list testrules
group [ testgrp ];
cmdrule no-sync-cmd {
    command "request devices sync-to";
    action  deny;
cmdrule no-sync-dev {
    command "request devices device ios-0..1 sync-to";
    action  deny;
cmdrule no-sync-dev-1 {
    command "request devices device ios-0 sync-to";
    action
A command that explicitly matches the cmdrule command string is denied (actually the sub-command is just not available):
testuser@ncs% request devices device ios-0..1 sync-to
% Invalid input detected at '^' marker.
But a sync-to for individual devices within the specified range is permitted since the cmdrule command string is not explicitly matched:
testuser@ncs% request devices device ios-1 sync-to
result true
Then second type of NACM rule is 'data authorization' which permits/denies access to a 'node' (and perhaps sub-nodes) of the CDB.
As you have seen here, the nacm 'rule' points to a node in the CDB tree - defined by the path, and determines the permit/deny criteria on:
"A rule matches if 'module-name', 'rule-type', and 'access-operations' match the request.
If a rule matches, the 'action' leaf determines if access is granted or not."
Any cli (or other API) attempting to access the node specified in the rule will be permitted/denied access to the node.
The sync-to node is defined as an action in the model, and therefore the exec access-operation is applicable.
Thanks for the clarification and example. I am still wondering about cmdrule and the general case (as mentioned I have it working now with a rule, but I am curious).  I tried the following but it did not work. I tried a '*' too but it was rejected.
Jim
Hi Jim,
In your example:
address 127.0.0.1;
NAME ADDRESS
xr-0 127.0.0.1
xr-1 127.0.0.1
NAME ADDRESS
xr-0 127.0.0.1
xr-1 127.0.0.1
NAME ADDRESS
ios-0 127.0.0.1
ios-1 127.0.0.1
j-0 127.0.0.1
j-1 127.0.0.1
xr-0 127.0.0.1
xr-1 127.0.0.1
Thanks for verifying that there really is a limitation with cmdrule that can be overcome using rule instead.  Are you considering raising a bug against cmdrule (low priority of course)?
Actually, from this discussion and revisiting the NSO Admin guide, I believe what we are seeing is the intended behavior.
From doc:
"If the group leaf-list in a rule-list entry matches any of the user's groups, the cmdrule list entries are examined for command authorization, while the rule entries are examined for rpc, notification, and data authorization."
Given this statement, permitting/denying access to elements defined in the CDB - including exec or actions such as per-device sync-form/to which can be accessed through many commands (e.g. many devices in command) should be handled through the use of 'rule' entries.
'cmdrules' being use for to permit/deny execution of system or global commands such as 'configuration' to disallow/permit ability to access config, or 'request system logout' or 'request packages reload' or 'request devices sync-to', etc.
Please make an enhancement request if you think this feature could better work differently or if you feel the documentation could better explain.
I've tried this solution with request devices device <devicename> sync-to and the process continued. I've also updated the rule-list with path /ncs:devices/device[name='$DEVICE']/sync-to and it also continued processing.
Jim A.
