How to maintain dispatch-map on NSO CFS node?
hgx1218
Hi, experts,
I'm now using a dedicate service called dispatch-map on CFS node, and it needs to be maintain manually. But I want change the way from manually to automatically.
I appreciate any tips on this.
rogaglia
Yes, upgrade to NSO 5.X....in NSO 5.X there is no more need for dispatch-map as the CFS node can read the device names in the RFS nodes but not their configurations.
Forgot to mention that you do need a special package that comes with NSO to avoid the dispatcher:
admin@upper-nso# show running-config devices device lower-nso-1 device-type lsa-additional-ned-id
device-type lsa-additional-ned-id tailf-nso-nc-5.3
then:
admin@upper-nso# show running-config devices device lower-nso-1 config devices device
config
devices device ex0
