How to read SNMP data in single JSON RPC request with some delimeters
gaubhatn
Hi All,
I have added and enabled the SNMP entity MIB to read the SNMP data for NSO managed devices.
In NSO UI I am able to get the data, but I need to fetch it for further processing in my application. Problem I am facing is I am getting the response but there is no delimiter to parse the response. Below I have attached the sample O/P I am getting for your reference.
Please find the NSO detail also, if you want to try it:
NSO: 10.126.78.217
Credentials: admin/admin
I am trying to run below query as post request:
     "jsonrpc":"2.0",
     "id":1,
     "method":"query",
    "params":{
         "path": "/ncs:devices/device{ios_192.168.99.194}/live-status/entity-mib:ENTITY-MIB/entPhysicalTable/entPhysicalEntry/",
          "th": 1
I am getting the below response:
    "jsonrpc": "2.0",
    "result": {
        "current_position": 1,
        "total_number_of_results": 2,
        "number_of_results": 2,
        "number_of_elements_per_result": 1,
        "results": [
                "1Catalyst 37xx Switch Stack1.3.6.1.4.1.9.12.3.1.11.20stack-1Cat37xx Stackingfalse"
                "1001WS-C3750X-241.3.6.1.4.1.9.12.3.1.3.9451chassis01V0512.2(55)SE1112.2(55)SE11FDO1732P2YEWS-C3750X-24T-Ltrue"
Gaurav Bhatnagar
Dan.Sullivan
Hi Gaurav,
I'm not sure I understand the issue here. Are you expecting more data returned by the query?
-Dan
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
