How to Rollback specific commit
Fantolino
I understand that rollback nnn revert all the changes since the one referred by nnn.
How can I revert only the changes made by a specific commit?
For example in the following sequence I set the IP address on fastEthernet1/0 and then on FastEthernet 1/1. Then I would like to revert only the first configuration.
cisco@ncs% set devices device SDWAN_netsim config ios:interface FastEthernet 1/0 ip address primary address 1.1.1.1 mask 255.255.255.0
[ok][2020-08-28 12:45:20]
[edit]
cisco@ncs% commit label SetIf10        Commit complete.
[ok][2020-08-28 12:46:04]
[edit]
cisco@ncs% set devices device SDWAN_netsim config ios:interface FastEthernet 1/1 ip address primary address 2.2.2.2 mask 255.255.255.0
[ok][2020-08-28 12:46:13]
[edit]
cisco@ncs% commit label SetIf11        Commit complete.
[ok][2020-08-28 12:46:23]
[edit]
cisco@ncs% show commit list 5        2020-08-28 12:46:32
SNo. ID       User       Client      Time Stamp          Label       Comment
1327 13274    cisco      cli         2020-08-28 12:46:18 SetIf11
1327 13273    cisco      cli         2020-08-28 12:45:59 SetIf10
1327 13272    cisco      cli         2020-08-28 12:44:34
1327 13271    cisco      cli         2020-08-28 12:42:57 SetIpFastEt
1327 13270    cisco      cli         2020-08-28 12:42:27 SetIpFastEt
[ok][2020-08-28 12:46:32]
[edit]
cisco@ncs% rollback 13273
[ok][2020-08-28 12:46:49]
[edit]
cisco@ncs% commit dry-run
cli {
    local-node {
        data  devices {
                  device SDWAN_netsim {
                      config {
                          ios:interface {
                              FastEthernet 1/0 {
                                  ip {
                                      no-address {
             +                            address false;
                                      address {
                                          primary {
             -                                address 1.1.1.1;
             -                                mask 255.255.255.0;
                              FastEthernet 1/1 {
                                  ip {
                                      no-address {
             +                            address false;
                                      address {
                                          primary {
             -                                address 2.2.2.2;
[ok][2020-08-28 12:46:54]
vleijon
Use rollback selective 12345 for this use-case.
vleijon
What about python maapi api, how to perform selective rollback in python ?
