how to set a node type in python
Hi all,
I'm going template-less as changing the config directly in python
here is my issue, i don't know how to set type node eg
svi = root.devices.device[host].config.ios__interface.Vlan[vlan_id]
svi.standby.standby_list[vlan_id].authentication.auth = 'md5'
svi.standby.standby_list[vlan_id].authentication.md5.key_string.type = '0'
svi.standby.standby_list[vlan_id].authentication.md5.key_string.secret = 'bob1234'
<ERROR> 29-Jan-2020::22:08:57.929 svi_fractus ncs-dp-39743-svi_fractus:main-1-th-18412: - Node type does not support assignment
<ERROR> 29-Jan-2020::22:08:57.929 svi_fractus ncs-dp-39743-svi_fractus:main-1-th-18412: - Traceback (most recent call last):
File "/opt/ncs/ncs-4.7.2.1/src/ncs/pyapi/ncs/application.py", line 368, in wrapper
pl = fn(self, tctx, root, service, proplist)
File "/var/opt/ncs/state/packages-in-use/1/svi_fractus/python/svi_fractus/main.py", line 306, in cb_create
File "/opt/ncs/ncs-4.7.2.1/src/ncs/pyapi/ncs/maagic.py", line 473, in __setattr__
raise MaagicError("Node type does not support assignment")
ncs.maagic.MaagicError: Node type does not support assignment
any one have an example on how to achieve this ??
Yale
vleijon
So, what happens here is that different types of leafs have to be handled differently. In this case auth is not a leaf, it is a choice. (and mostly invisible in the data tree) If we look in tailf-ned-cisco-ios.yang in the ned it looks like this:
        // interface * / standby * authentication
        container authentication {
          tailf:info "Authentication";
          choice auth {
            leaf word {
              tailf:cli-drop-node-name;
              tailf:cli-disallow-value "md5|text";
              type string {
                tailf:info "WORD;;Plain text authentication string (8 chars max)";
            container md5 {
              tailf:info "Use MD5 authentication";
You probably want to write md5 to authentication.word instead.
vleijon
          choice auth {
            leaf word {
              type string {
            container md5 {
