How to write NSO-action (python) to get its dry-run output?
viskakka@cisco.com
Got a requirement to create a NSO action wherein customer want ability to run action to see its dry-run output, before actually committing the action. Is it possible? Any example would be great help.
lmanor
Dry-run is a service action, here is an example of how it can be run, this does native device output, can also used cli and xml - see tailf-ncs-services.yang for details:
              # Run dry-run before committing
              dryRun = root.services.commit_dry_run
              drInput = dryRun.get_input()
              drInput.outformat = 'native'
              self.log.info('tryAction: Dry-run outformat : ', drInput.outformat)
              drOutput = dryRun(drInput)
              if drOutput.native != None :
                devlist = drOutput.native.device
                for dev in devlist :
                  self.log.info('tryAction: Dry-run device: ', dev.name)
                  self.log.info('tryAction: Dry-run data: ', dev.data)
-Larry
lmanor
-Larry
Hi Larry,
Thanks for sharing above way to output dry run output. But i am still missing something.
My action(Its not a service) is applying a template. So requirement is to run this action to produce dry-run output before actually applying changes to network.
So my action yang is taking an input argument to check if invocation is just to produce dry-run or actual commit.
based on this argument, i need to write python logic to either just produce dry-run output for user OR actual push.
Vishal.
Hi Vishal
Larry gave you the correct way to do this...
But to add a few more details, assuming you have (in part) some YANG like this:
  container action {
    tailf:action trystuff {
      tailf:actionpoint tempBar-action;
      input {
       (...skip)
        leaf doDryCommit {
          tailf:info "dryrun or commit";
          type enumeration {
            enum dry-run;
            enum commit;
          default "dry-run";
      } // input
then you Python will look (something) like this:
        with ncs.maapi.single_write_trans('admin', 'tempBar') as t:
            try:
                vars = ncs.template.Variables()
                                vars.add('DEVICE', input.device)
                vars.add('HNAME', input.hname)
                vars.add('DNAME', input.dname)
                                  root = ncs.maagic.get_root(t)
                context_node = root.ncs__devices
                tmpl = ncs.template.Template(context_node)
                tmpl.apply('tempBar-template', vars)
                # dryrun-native
                       if str(input.doDryCommit) == 'dry-run':
                        if len(devlist) != 0:
                            for dev in devlist:
                                self.log.info('tempBar: Dry-run device : ', dev.name)
                                self.log.info('tempBar: Dry-run output : ', dev.data)
                        else:
                            self.log.info('tempBar: Dry-run output : NO Dry-Run found')
                # commit
                       else:   # commit selected
                    self.log.info('tempBar: commit template apply')
                    # commit transaction
                    t.apply()
                self.log.info('tryAction: Host ... : ', input.hname)
                output.result = "all done"
            except Exception, cause:
                res = str(cause)
                self.log.info('tryAction: Exception: %s ', res)
                output.result = "exception"
            finally:
                t.finish_trans()
hope that helps
Gregg
Thanks Gregg for detailed example.
I am able to implement it in my action, appriciate your inputs. Thanks to Larry too.
